help!!!!!! car running mad rich
hey i did a ls swap im my 88 hf crx i left everything obd0 and now the car is smoking and itz stfraight fumes coming out i cheacked timing that good i swaped the injectors and thats good i also put a fuel pressure regulator on the line and no help now im completely confused can any one help or has any one had this problem lmk thanks
Does the car run?
If so,
How does it run? Is it misfiring?
Does it sound like its running on 3 cylinders?
Did you change your fuel filter?
How long was the car sitting for? Make sure you have fresh fuel.
When you say timing, you mean mechanical timing right? As in, cam to crank?
How is your firing order?
If so,
Does the car run?
If so,
If so,
No I never replaced the filter
The car was never sitting the ls motor was for about 3 months
Yes cam to crank timing if good
As for the firing order. I could never get it rite I'm always guessing really
been the same since forever!.
capm.stabahoe
Dec 27, 2008 06:17 PM
