FS: Built 10sec GSR short block for boost
For sale is my built (stock sleeve) 81.5mm GSR b18c1 short block. block contains: CP 9:1 comp pistons, eagle H-beam rods (newer style w/ upgraded rod bolts) balanced/micropolished OEM LS 89mm crank, ACL race bearings, ARP oil squirter block offs, OEM GSR water pump, OEM GSR timing belt, OEM GSR oil pump. All machine work done by Fisher automotive. This short block is 100% complete! Everything has less than 2k miles and is in GREATTTT shape! I went 10.95 at atco the week before pulling the motor! (many ppl can vouch for this) There is NOTHING wrong with the motor at all! the only reason i pulled the motor is because i wanted to go with a bigger setup (again many ppl on here can vouch for how healty this block is) i want $1000 which is a GREAT price (parts alone are worth more than that)
heres the block fresh out of the machine shop
heres how it looks right now
heres a vid of a 10sec pass
http://www.jrspeedtv.com/ATCO/JUEVES...202/VIDEO6.wmv
as u can see from the vid, the motor doesnt smoke at all!!
also interested in the dyno numbers and more pics.
Are the clearances loose enough to run this engine in the winter? Dont want to spin a bearing due to thick oil one day =/.
boostedb1810psi
Northeast (Sales)
Jul 28, 2007 03:55 PM
boostedb1810psi
May 28, 2007 07:22 PM
