S2000 manifold
Old Apr 18, 2011 | 01:52 PM
acidz's Avatar
Default S2000 manifold
my first s2000 manifold and my 3rd manifold ever....i know there are places to improve, but if you guys wanna shoot up some positive or negative comments your more than welcome. i have been learning new things everyday while building these and i know one thing i really need to improve on is bead consisity.
Old Apr 18, 2011 | 03:24 PM
RACEPAK's Avatar
Default Re: S2000 manifold
looking good,
Old Apr 18, 2011 | 06:08 PM
russianvr4's Avatar
OG Fabricator
it looks like you could use a little bit more heat, use a larger gas cup too. otherwise looks pretty good!
Old Apr 18, 2011 | 07:21 PM
opc's Avatar
opc
that looks amazing.. how do you actually figure out the bends? on paper, a mock out of cardboard/plasti, eye ball it?
i would love to know.. thanks !
Old Apr 18, 2011 | 07:52 PM
SovXietday's Avatar
Any bracing? Looks like there's going to be a lot of stress on that manifold from the turbo's position.
Old Apr 19, 2011 | 05:35 AM
acidz's Avatar
whats the heat setting your welding sch10 pipe at and i have a number 8 cup, but need to get the large gas lense for the number 10 and 12 cup i have.
Old Apr 19, 2011 | 05:42 AM
acidz's Avatar
there is a brace holding the turbo to the block.
Old Apr 19, 2011 | 08:11 AM
weiRtech's Avatar
OG Fabricator
looks good rene. i bet the collector joints were fun to do. only thing i'd add would be a brace to the wg branch at the collector.
Old Apr 19, 2011 | 12:41 PM
SovXietday's Avatar
Looks good dude!
Old Apr 19, 2011 | 12:58 PM
ExVtec's Avatar
Looks good, just keep in mind the oil drain. Give yourself plenty of clearance there w/the front crossmember.
Old Apr 19, 2011 | 07:20 PM
russianvr4's Avatar
OG Fabricator
well, adding heat wont necessarily fix it. what im referring to is how your weld bead has 'peaks'. thats either from not enough heat, moving too fast/adding too much filler or combination of all.
try either going slower, adding heat or slowing down with the filler to keep it consistent.
SwappedTURBOegg
Welding / Fabrication
29
Feb 16, 2014 05:36 AM
Fizoust-gsr
Jul 21, 2011 11:46 AM
B18 CYA
Nov 18, 2006 07:45 AM
PhatS2000Turbo
12
Feb 13, 2006 05:45 PM
Mase
Honda S2000
14
Nov 1, 2003 01:56 PM
