what did you brake first since your swap
Old Apr 18, 2011 | 09:13 AM
rick_rabies's Avatar
I'm not Rick!
Default what did you brake first since your swap
jus curious. post what you broke first lol
i broke an axle
then wheel studs
then clutch
Old Apr 18, 2011 | 09:41 AM
I'm not Rick!
Default Re: what did you brake first since your swap
^i guess so lol.
piratemcfred...good to see you agian. your threads have tought me quite a bit.
Old Apr 18, 2011 | 09:43 AM
speedooo's Avatar
So far just two axles and some old mounts :crosses fingers:
Old Jun 6, 2011 | 06:46 PM
TisforTurbo's Avatar
nothing so far! 30,00 km. Fingers crossed.
Old Jun 15, 2011 | 03:36 PM
Civic_4life's Avatar
2 set of axels, really need to work on my preload or stop using autozone lifetime warranty axels thats bout it, 10-13k miles so far!
Old Sep 11, 2011 | 11:20 PM
capsoval's Avatar
#3 rod let go....Had to start over. Broke at 6500rpm while doing a pull. Was a 2005 Z1 with 30k on it.
Old Sep 12, 2011 | 01:01 PM
Sp00nFed EM1's Avatar
Any more info on the setup? Pistons, rods, etc?
Old Sep 12, 2011 | 11:01 PM
capsoval's Avatar
Well, my particular setup doesn't belong in this section because its a boosted setup.
Stock Z1 , prb intake, supertech seats/springs/retainers. Custom T4 divided manifold, GT4088r w/ 4" DP. 1000cc RC injectors. 18psi on E85 runnng Kpro. Made 370whp for about 1.5 years and had just been retuned on E85 making 480whp for about 2 months. Only the block and baffle plate were wasted, oil pan, oil pump, crank and head all fine.
Old Sep 14, 2011 | 12:26 PM
chad's Avatar
Moderator
swapped since 2004 and have yet to break anything!
Old Jan 18, 2012 | 03:59 PM
moneymaker07893's Avatar
About 4 axles.... Then a clutch at the end of the year lol
Old Jan 19, 2012 | 06:25 AM
JW racing's Avatar
All motor,Pure road race car - Swap since 2007. Used K20A3, K20A, K24 and more... Other than burning alot of TPS sensors initially and binding one axle. I have not broke anything, just spun a few rod bearings here and there.
Old Feb 21, 2012 | 08:46 AM
kteggy88's Avatar
I needed new brakes right away! Lol
Old Feb 25, 2012 | 08:11 AM
.dave's Avatar
i HAS questions ?
Timing chain tensioner broke after off in the block within 200 miles of getting my swap running. Lesson learned: don't make large purchases from shady people over the internet. There were numerous things wrong with/missing from the swap that I bought, including a dead ECU.
I bought another shortblock that I was going to just swap in and leave stock, but I ended up deciding to throw pistons and rods in it, and ended up with a fully built 2.0 liter.
Old Feb 25, 2012 | 08:18 AM
crappyhatch's Avatar
2 axles, a clutch, and #3 cylinder wall.
Old Mar 15, 2012 | 07:44 AM
JDMilanoRed's Avatar
Bent some valves due to over-rev (learn to drive, nub) but got to pull my motor out and rebuild the head... dropped in some cams, dual springs, retainers, .5mm over, mild port/polish, RBC intake : D
Broke my TPS on the dyno... bought the k-tuned aluminum TPS...
Old Mar 16, 2012 | 07:14 AM
JW racing's Avatar
TPS sensors without a doubt are the most wide spread problem amongst K-series users. I started a whole TPS thread on k20a just to solve the problem and thanks to that, Ktuned is using that thread as a marketing tool and selling sensors like mad. I still prefer the REAL honda OEM sensors, it is the aftermarket OEM knock offs that are the big problem like BWR and Omni.
Old Mar 20, 2012 | 12:39 PM
To be perfectly honest, I still havent gotten mine quite right... I tried the BWR and the Omni and had quite a few problems... I have the ktuned sensor on there now, but theres still an issue... seems like at very low throttle, the car balks and randomly misses... almost as if theres a hole in the kal for that range...
I prefer OEM stuff as well, but the only way to get an OE TPS is to buy an OE throttle body... and Acura is very, very proud of that thing ($$$$)
square_1
May 3, 2011 05:12 AM
SalisburyLax
11
Apr 4, 2008 09:44 AM
fventura03
Jul 1, 2006 07:08 PM
sbcrx
Jun 29, 2004 08:08 AM
jameskersten1
Apr 24, 2004 04:44 PM
