oil light at low rpm?
Old Apr 17, 2011 | 11:29 PM
spiffy_civic's Avatar
Default oil light at low rpm?
Ok every1 so my oil light flickers at low rpm when at idle when i bring rpm back up it go's away. Do you think it could be a faulty sensor? loose wiring or oil pump.. Just re-built the engine and now its doing this.. Runs great a little valve noise from needing adjustments.. Any input is greatly appreciated :D Thanks every1
Old Apr 18, 2011 | 01:23 AM
DCRB's Avatar
Default Re: oil light at low rpm?
you need to hook up an oil pressure gauge to know for sure, but either the sensor's bad, the pump is bad, or your pick up is clogged. i wouldn't drive the car till you know for sure what's up
Old Apr 18, 2011 | 02:29 AM
yea i just re-built her and the pick up is clean i know that 4 sure. And it only does it every once in awhile so im thinking faulty sensor but idk im no pro. sensor is cheap gonna buy it if it go's away ill know but if it dont then ima go ahead and replace the pump and pick up screen thing.. I cleaned it with brake parts cleaner b4 i re-installed it back on the car and it was a little dirty and cloggd with gunk but after it was clear and clean so idk pump looked new but cant tell by eye. Sensor is bad im betting
Old Apr 20, 2011 | 05:21 PM
10sec4door's Avatar
i would def check the pickup. takes an hour and its very worth it. just found out mines was very cloggoed.
Old Apr 21, 2011 | 01:20 PM
I checked mine it took me 30 mins 2 pull off.. I also have race header and done it a billion times so yea lol.. But thanks for the input! It was clogged and my rod bearings were bad
tollickj
21
Jul 17, 2022 07:35 PM
92 CiviC H.B
Apr 26, 2010 02:56 PM
heefro757
Feb 8, 2009 04:32 PM
psegs80
May 19, 2008 07:44 PM
tiannalind
Feb 28, 2007 03:15 PM
