Dc2 seats in a Crx?
I have a friend selling a set of Black Gsr leathers from his teg for cheap and i wanna know if they will fit in my crx. or will they sit to high or whatever.
and what other seats will fit in it?
I was looking for this info as well. I searched google and found one or two write ups. Not sure how different the floor pan is in a CRX from a regular EF hatch, but apparently EF's in general are tight on room.
One guy took his stock EF seats, removed the upholstery and cushions. Did the same thing for his DC2 seats and transplanted the cushions and skins onto the EF seat pans. He used zip ties to hold the seat upholstery on the Civic seat pans, and was able to use the stock EF seat tracks. Otherwise, I think this type of transplant is going to require some metal work and fabrication.
If you find any more info on this, keep me posted. I'm thinking about buying an '89 hatch and the driver's seat is pretty shredded.
i have dc integra LS seats in my 89 hatch. they dont swap over whatsoever. seat pan swap also will not work because the integra seats has like a spring instead of a pan. I welded brackets together to make them work. took some time to do. hope this helps
ZeRoFouR-EF9
Apr 7, 2002 11:25 PM
