Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
bad noise inside the car
Old Apr 17, 2011 | 08:34 PM
rspdron's Avatar
Default bad noise inside the car
Hello I have a Honda Civic 05 lx coupe and I have a problem.There is very bad sound somewhere from the front when I start driving the car even 10 miles an hour it's not a tires for sure already checked I lifted the front of the car took of the wheels and put the gear on Drive and started to listen but it doesn't sound like it's wheel bearing it looks like the sound comes from somewhere further from the wheel hub...... maybe somebody already had that problem
please help me
Old Apr 17, 2011 | 09:46 PM
It Wasn't Me's Avatar
Default Re: bad noise inside the car
A better description of the noise you're hearing would help.
Are you sure it's not the bearing? It will make a lot more noise with the weight of the car on it than it will just spinning in the air on jack stands.
With the front of the car jacked up; have you tried shaking the top of the tire towards-and-away from the car? If it wiggles, the bearing is likely bad.
What about the brakes? Have you removed the wheel and inspected them?
How do the axles look?
Old Apr 18, 2011 | 05:32 PM
rspdron's Avatar
brakes are fine,I tried to shake the top of the tire no sound I didn't inspect the axles cause i don't know how ...it look like the sound goes from them by the way this car was in accident before i bought it looks like the impact was in the front drivers side because of fresh paint on the left front wing
Last edited by It Wasn't Me; Apr 18, 2011 at 09:10 PM. Reason: Fixed the quote code.
Old Apr 18, 2011 | 09:15 PM
What kind of noise does it make while you're driving?
Grinding?
Clicking or popping?
Variable rhythm, like a "wah-wah-wah" noise?
How loud is the noise?
There's only a handful of things it could be if it's associated with the axles, wheels, or suspension components.
Check the CV boots for leakage. Also make sure your transmission fluid level is where it should be.
Old Apr 19, 2011 | 06:19 PM
rspdron's Avatar
Grinding?
Transmission fluid level is ok and the CV boots are fine the car are only 6 years old and has 90k miles ... the sound is like growing buzz and it goes louder when you speed up.I also tried to seed up and geared to neutral the same noise and I tried to speed up and terned off the engine the same noise
Old Apr 19, 2011 | 07:46 PM
Orangegsx's Avatar
Sounds like a wheel bearing. If you have a lift get the car up and let it run in gear. Use a stethoscope against the knuckle and compare sounds from left knuckle to the right.
enriquezf
Honda Civic (2006 - 2015)
Jan 16, 2019 05:48 PM
bambbrose
Oct 11, 2015 08:01 AM
ramboPandA
Mar 23, 2015 08:41 AM
zjknicks
Suspension & Brakes
Mar 6, 2014 06:18 AM
Josh.
14
May 30, 2005 09:47 PM
