H22 swap question
Old Apr 17, 2011 | 06:43 PM
hatchdrvr's Avatar
Default H22 swap question
Swapping JDM H22 into 97 lx, can I use my f22 fuel rail with the H22 injectors, or do I need to pick up the US spec Prelude fuel rail? Also converting to OBD I if it makes a difference.
Old Apr 18, 2011 | 06:05 PM
hatchdrvr's Avatar
Default Re: H22 swap question
No one?
Old Apr 18, 2011 | 07:26 PM
nus_dogg's Avatar
You need to find a H22 fuel rail feeding from the driverside because thats where your fuel filter line is at. And no, I don't think the F22 Fuel Rail will work.
Old Apr 18, 2011 | 09:15 PM
gogydm's Avatar
What year is the engine you are using?
Old Apr 18, 2011 | 09:24 PM
hatchdrvr's Avatar
nus dogg: thanks, I figured as much. I will pick up a prelude fuel rail.
gogydm: I will be ordering a 92-95 OBD I motor in the next couple of weeks. I'm just trying to round up odds and ends for the swap.
Old Apr 19, 2011 | 12:58 PM
gogydm's Avatar
Are you sure that the fuel feed is in the passenger side on that motor?
Old Apr 20, 2011 | 05:22 AM
loup05's Avatar
If its a motor from japan the banjo bolt that goes to the fuel rail will be on the driverside.. all you have to do is use your stock fuel rail along with the H22 injectors
Old Apr 20, 2011 | 01:37 PM
benoit's Avatar
im doing a h22a swap in my 6th gen accord right now. watch on what timing belt kit you get the water pumps are different from jdm- usd. i made that mistake. also jdm engines need you to reroute a wire to the dizzy. ill get all the info once the swap is done
Old Apr 20, 2011 | 02:33 PM
hatchdrvr's Avatar
Thanks for the tip, I was planning on ordering a new water pump from Honda when I get the new timing belt set. Are the pumps themselves different or just the pulley?
Old Apr 20, 2011 | 06:09 PM
nus_dogg's Avatar
There's a few that comes feeding from the passenger side; might've been the JDM H23As, but I did read during the process of my H22 swap that you'll need to buy another fuel rail feeding from the driverside so that tells me that there are some with it feeding from the passenger side. And mine came feeding from the driverside, so I sold the extra rail I bought to someone else.
Old Apr 21, 2011 | 02:31 AM
holmesnmanny's Avatar
Ya, yours and his are both 5th gen so the fuel filter is on the drivers side so he can use his stock fuel rail and H22 injectors. If it was 4th gen he'd have to use 4th gen fuel rail.
Old May 12, 2011 | 05:19 PM
assassin12's Avatar
hey wuts up
So I just picked up a 96 accord coupe and I want to do a H22a swap on it what will I need to get it done right.. I read on this forum that the H22 should just drop in with very little mods and the motor Im looking at is a 98-01 H22a with the tip tronic tranny..
Old May 12, 2011 | 07:33 PM
HONDA1luv's Avatar
^^^ go to the FAQ, look around the do some research.
And start your own thread if you still got Q's
Old May 16, 2011 | 07:45 PM
gogydm's Avatar
Originally Posted by assassin12
hey wuts up
Those tiptronics are tricky, Idk if anyone has gotten one to work normally with no CELs.
Old May 17, 2011 | 05:28 PM
Mossvk21's Avatar
Im thinking of doing an H22 swap as well but im going to build mine up before i drop it in... need a 5 speed trans first
Old May 19, 2011 | 01:54 PM
stormbuggy2002's Avatar
i just did a swap from my h22a to a h23a vtec blue cover...i believe ive connected back all the wirings from my old one to my new one...i even swap my oil pump plate along with the pick up tube so i could reuse my crankshaft sensor and top dead sensor....before i did this, car will not start...so i transferred my sensors to my new one and still would not fire up..any suggestionss...
Old May 19, 2011 | 01:55 PM
additional info...i have used all my parts from my old h22 to my h23 motor..
egCivicH22
Aug 15, 2007 09:35 AM
egCivicH22
Aug 14, 2007 07:49 PM
M2B4
Feb 21, 2006 06:07 PM
DCFIVER
Oct 16, 2004 01:01 PM
