95 civic ex suspension
Alright well im kinda newso idk if theres already a thread for this but i need sum help wit Ma suspension.
Well im looking to spend mayb 700 or less. I want a good ride but also a nice set up? I have a 95 civic ex. Has 17s now but goin to change them to 16s or 15. I use it as a daily driver. And (if it matters) i plan on getting a b18c1 swapp sometime this month
For under $700, Progress CS-II with the lighter spring rates.
And could you PLEASE type in normal English please?? Your posts are pretty difficult to read and make you seem under-educated.
Ok well i want it a nice low stance. Ill try and post up a few pictures once i hve my internet cut back on. And yea sorry im typing off my phone nd im used to txt language so ill try to type normally.
Thanks guyz. It would be really helpful if Yu could post up links to the suspension kit you talk about. Thanks alot again guys and appreciate the help.
Do you want a 'low stance', whatever that is, or do you want the car to handle well?
This is what is usually considered a functional ride height. I've got the progress CS-II with 350F/350R spring rates and a 22mm rear swaybar.
Even a little lower than that the progress can handle. You just need to get the 500lb springs for the front and 350lb springs for the rear to avoid bottoming out.
Or with konis you could probably get away with 450 front and 300 rear.
