starter realy in the middle of dash?
Old Apr 17, 2011 | 02:50 PM
booted_wishes09's Avatar
Default starter realy in the middle of dash?
i have a 94 accord. The haynes manual say that the starter relay is "in center dashboard next to PGM-FI " I cant seem to find it. Any help?
Old Apr 18, 2011 | 09:50 AM
Default Re: starter realy in the middle of dash?
bump
Old Apr 18, 2011 | 05:30 PM
poorman212's Avatar
Not sure what you are looking for.
What is the issue?
Old Apr 18, 2011 | 10:53 PM
im looking for the starter relay. the problem i am having is when i turn the key the first 2 poisitions are ok but when i put it in the 3rd all the way back the dash lights go out and it dosent crank nothing a few secs later the dash lights come back on.
Old Apr 19, 2011 | 08:36 AM
StreetsideStig's Avatar
Is it the same as the main relay on a 94? I wish the manuals had more actual photographs. It took me forever to find the main relay on my '90, because all I could see on the diagram was a little hand-drawn box.
Old Apr 19, 2011 | 10:55 AM
no its diffrent than the main relay. Yeah the diagram i have just shows a little box and says starter relay under it
Old Apr 19, 2011 | 10:29 PM
slomofo's Avatar
GDD Member
Main relay and starter relay are the same.
If your dash lights are going out, it's most likely a faulty ignition switch, weak battery, or dirty/corroded battery cables.
Old Apr 20, 2011 | 10:37 AM
im pretty sure the main relay and the starter realy are 2 diff things. I tested the switch and it was good. The battery and all cables are good also
Old Apr 20, 2011 | 12:12 PM
slomofo's Avatar
GDD Member
There's no starter relay, only main relay which sends power to the starter and a starter cut relay which cuts power to the main when the clutch pedal switch circuit indicates that the clutch isn't down.
Anyway, here you go sir... starter cut relay:
Old Apr 20, 2011 | 09:37 PM
ok that is something like what im looking for my car is an auto. so i should just be able to just stick my head under there and see is or do i need to pull out the center console? thanks for the help
Old Apr 21, 2011 | 02:39 PM
poorman212's Avatar
Can I ask what problem you are having? If you notice the little footnote the start/cut relay is for Manaul Trans.
Old Apr 22, 2011 | 01:38 AM
hatchet_honda's Avatar
have you tested the starter? simple to do...hook it directly to the battery with jumper wires. it should fire up. if not well uhh oohhh
Old Apr 22, 2011 | 03:41 PM
poorman212's Avatar
Originally Posted by hatchet_honda
well uhh oohhh
I'd then check the battery as well......
EF7
15
Mar 17, 2022 08:27 AM
bigjefft
21
Apr 29, 2012 12:01 AM
thegatekeeper14
Apr 8, 2008 06:28 PM
rass1313
Apr 14, 2006 02:41 PM
xci_ed6
Jan 3, 2004 10:47 AM
