d15 oil leak odd location.
Encircled is the area of the leak, I'm 99% sure it's oil. I pressure wash it away and it slowly comes back after driving. Any chance it's the headgasket leaking out from there? I know for sure there is no coolant/oil mixing.
Thanks in advance.
Maybe? Has OEM gasket as I'm not aware of any maintenance of this car. It runs awesome and doesn't leak or burn anything other than this one spot. Would a cam seal leak end up there?
Yeah. I'll tinker with it a bit this weekend maybe. But would I be far off in including the headgasket in the possible culprits? Anyone seen one leak externally like that on one of these before?
Bump, just wondering if anyone's seen an external headgasket leak before. The dizzy side is completely dry. Another thing I thought I'd toss in there is one of the hoses at the intake manifold coolant pipes was leaking so I just looped the lines, no issues should arise from this I'd assume?
I've owned 8 rex's and three of them had the same leak. I consider it normal seepage and it won't hurt anything.
Of course you could change it and fix it but I wouldn't worry.
After finding the same seepage on the third one, I never changed the gasket and it never got worse. My curent HF has the same leak and has for the three years I've owned it and it is still running strong.
93grayeg
Sep 24, 2018 03:46 PM
