Classic Hondas All Pre-1988 Hondas.
How much compression should a 84 Accord LX have?
Old Apr 16, 2011 | 04:38 PM
G. Man's Avatar
Default How much compression should a 84 Accord LX have?
Hello, I'm looking at buying a 84 Accord LX hatchback with the 1.8L engine tomorrow. I plan on doing a compression check, and just want an idea of what would be normal for this car. I've never done a compression check, but am going to buy one before I go look at it. Any help would be appreciated! Thanks!
Old Apr 17, 2011 | 06:30 PM
realred96's Avatar
Default Re: How much compression should a 84 Accord LX have?
No expert here, but I would think 160-190 PSI would be good. It is also important to note that there should not be more than a 10% difference between the individual cylinders.
Make sure you have a well charged battery, disconnect the coil to distributor wire, remove all the spark plugs. When turning over the motor, put the throttle pedal to the floor also.
bethdon
Apr 11, 2017 08:56 PM
accord96lx
Jan 6, 2012 11:13 AM
02AccordSE
Oct 17, 2009 10:01 AM
k1ke77
Jul 18, 2007 04:21 PM
