MAIN RELAY PROBLEM!!!! NO POWER TO THE MAIN RELAY!!!
92 acura integra
95 obd1 b18c1
original wiring harness
car died yesterday after a 20 min drive. only factor that was different from my normal driving was my friend in the passenger seat...
okay so I have searched everywhere and cannot find a wiring diagram for the main relay power supply.
I have my girlfriends 92 integra here with me so I can figure this out but it isnt helping.
I have power to everything except the 2 hot wires on the main relay plug and the cruise control switch. I found 2 blown fuses one was the 40 amp blower motor fuse under the dash and the 7.5 amp fuse on the underhood fuse box. I changed the underhood fuse and my seatbelts started to work again. but still nothing to the main relay plug. I have not yet changed the 40 amp fuse but I do not have a blower motor so I was just wondering if this fuse also controls the main relay.
any help is greatly appreciated
95 obd1 b18c1
can someone help!!!
I need to have my car running by 9 am tomorrow morning
I got one power wire sorted out but I cannot figure out why this other one is still not getting power
Try this: http://manualspace.com/acura-integra...ng-diagram.htm
PDF link under the picture - looks useful.
Good luck
Good luck
thank you for that link I found the problem
it was the alternator solenoid valve fuse but every time I checked it it was passing the continuity test because the piece inside the fuse that had popped was bent over and slightly touching the other side.
