Clutch problems w/ 98 LS Teg. Need help.
Old Apr 16, 2011 | 03:11 PM
bluegatorade18's Avatar
Default Clutch problems w/ 98 LS Teg. Need help.
Ok, heres the deal. I need help. This is my daily driver also...I work pretty much everyday...
Anyways... I jacked the car up and it is sitting on four stands right now. The whole car is off the ground including all four tires. I can start the car up just fine. I can go through all of the gears with or w/o pushing in on the clutch, but when I put the car into gear the front tires will spin(fwd car, obviously). When I push in on the clutch the tires will stop spinning. It doesn't make any sense. What should I do?
Old Apr 16, 2011 | 08:00 PM
53JDMDC2's Avatar
Default Re: Clutch problems w/ 98 LS Teg. Need help.
why did you jack the car uo and do that? did you have a problem or just screwin around?
I have a 98 RS and have never done that so i dont know if its normal. doesnt sound normal.
PreClude
Nov 21, 2012 11:37 AM
bluegatorade18
Apr 18, 2011 02:48 PM
bluegatorade18
Apr 17, 2011 06:08 PM
9LsTurbo1
Oct 15, 2006 11:43 AM
