NY LGT. A Subaru that won't blow up
Posting this up for a guy I know. Legacy GT
Heres his email address cosseyowns@gmail.com
With the purchase of the M3 and X5, the LGT no longer has a place in my driveway. It's the car I've owner longer than any other, and it has treated me mostly well besides some warranty work.
Motor/drivetrain:
XO2 (ebay) exhaust, slightly modified for clearance.
Walbro 255lph fuel pumps - Including a full surge tank setup to combat fuel starvation on track, which I haven't had an issue with since this setup was put together and installed by Adam Hennessy (RRF).
Invidia Catless Divorced Bellmouth downpipe
Cobb SF Intake & Airbox
Invidia uppipe
Perrin BCS
Perrin BOV
06/07 WRX flywheel
ACT heavy duty pressure plate w/ full face organic disk
IHI VF52 turbo
Perrin turbo inlet
Cosworth 2.6L short block w/ 81mm billet crank
GSC S1 cams/valvesprings/retainers
RRF port work on the head
Moroso aluminum oil pan
ARP head studs
TorqueMaster engine mounts
Group-N transmission mount
RRF oil cooler
Cosworth 12mm high pressure oil pump
Gates timing and accessory belts
Koyo radiator
Suspension/Brakes/miscellaneous:
DBA 4000 series slotted rotors, front and rear
Goodridge stainless lines
Kartboy short shift kit
Kartboy exhaust bushings
GT Spec undertray
Bilstein HD struts/shocks
Swift springs
Whiteline sway bars, front and rear
Whiteline Roll-center and Bump-steer kit
Perrin Sway Bar End Links
Perrin PSR System
Defi Advance CR boost and oil pressure gauges
Defi Advance CR Link
OZ Allegerita wheels, 18x8 +48 w/ NO tires
Stock 17's w/ Michelin Pilot Alpin PA2 winter tires
I *think* that's it.
I originally bought the car in early 2007 from Goldstein Subaru in Albany, NY. It went through an OEM turbo and bottom end which were both replaced under warranty due to an oil starvation issue which was resolved when the motor was rebuilt. On May 1, 2010 I was at Lime Rock Park where the motor went again, this time cyl #4 ringland. I had a track event at Watkins Glen two weeks later, so I had to scramble to find an already built shortblock that was in stock. I ended up ordering a Cosworth short block w/ the 81mm stroker crankshaft from Rallysportdirect, along with several other items in order to make motor run it's best, including the Cosworth 12mm high-pressure oil pump, ARP head studs, Moroso oil pan, the engine and tranny mounts, and a few other things. I also ordered the new Defi gauges at that time, because I was under the impression my AEM gauges done broke on me, in which case a fuse was blown (F me, right?). The new Defi gauges match the gauge cluster almost perfectly, even with the red ring around the dials. Upon completion of the swap, I went to EFILogics to get the car tuned, where at the time (mid/late June on a very humid day) I put down 299whp and 295ft lbs. The motor wasn't completely broken in, so I went back a month later for a re-tune and put down over 300whp and 325ft lbs. The car pulls SOOO smooth and feels excellent in every way. As of right now, the short block has about around 9,000 miles on it.
The car has nine or ten track days on it and a couple autocross events. The car is pretty damn good on track, and handles very well. I've been able to overtake several Porsche GT3s, STis, EVOs, Corvettes, Mustangs, etc.. in the car without any issue. With the current setup on the car, I feel I have achieved an almost-perfect balance of power, handling, and braking.
The bad:
Carpet under the driver's throttle/brake pedel is torn due to not being able to use mats on track (the get in the way, go ahead and ask Toyota how the work)
Has two accidents. One was in May 2009 which was <5mph but ended up being the reason for the whole new JDM front end. The other was in February where I was lightly t-boned by a semi truck. Sounds bad, but only caused $2,000 in damage. The repair was done at Neal's Auto Enhancing on Central Ave, and came out excellent. Most on here know the caliber of his work is amazing, and his work on this car is no different. I will have the car detailed prior to buyer picking it up.
As far as price goes, I am open for negotiating, but I would like to get $15,000. I'm also including the OEM radiator, BOV, downpipe w/ cat, uppipe, and anything else I can find.
Motor/drivetrain:
Invidia uppipe
Perrin BCS
Perrin BOV
06/07 WRX flywheel
IHI VF52 turbo
Perrin turbo inlet
ARP head studs
RRF oil cooler
Koyo radiator
GT Spec undertray
Swift springs
Perrin PSR System
The bad:
