07 si squeeking and creeking ? HELPPP!!
hey guys i have a 2007 si coupe a few months back i put the d2 rs coilovers in my car also got the skunk2 rear camber arms and front camber kit. i was told until the suspension brakes in i will hear some creeking and squeeking from it. well about 4 months later i am still hearing these noises. actually they have gotten worse from when i first installed them. does anybody no what this could be or what its coming from. has this happend to anyone else? the noises are only coming from the rear the front seams to be fine! any answers will be a huge help!! thanks !
my car always made noises from the rear when i was on buddy clubs and never went away; had those for a year. if its getting worse, maybe check to see if you tightened all the bolts is the first place id check
From my understanding, when u upgrade components in ur suspension such as bushings, ball joints, etc to something that uses polyurethane in place of the factory rubber, they tend to creek and squeak unless u lube the s**t outta them. I know my old DA was like that I just never got around to fixing it.
Check out the camber kits for sure seeing as though they do have poly urethane in the pivots, after I put them in my DA they def squeaked. You could try a spray type lubrication but ur more than likely gonna have to take them off and put something in there and reinstall them.
MyDad'sCivic
Dec 4, 2016 05:10 PM
Type_R_Nammer
Suspension & Brakes
16
Oct 29, 2009 03:04 PM
Dracomeister
Honda Civic (2006 - 2015)
Jul 10, 2008 01:39 PM
Silroan
May 23, 2004 06:13 PM
