balance shaft/engine rebuild question
Old Apr 16, 2011 | 04:45 AM
usdmftw's Avatar
Default balance shaft/engine rebuild question
i am in the process of switching out a block in my cb7, i had a head bolt strip out on me. i have decided to rebuil th emotor and had a couple questions. i was originaly going to use my crank and rods in the new block. wanting to know if i can do that or should i try to use the crank and pistons from the block since they are mated together better? and the balance shaft need to stay wih the block it came with? my intial plan was to get bare block and swap all my parts over. but now thinking i should just get a shortblock and rebuild everything in it. and last question is how to to remove the balancer shaft from the housing/gear thig? i removed the 12mm bolt from end and looks like it pressed on there, any help? thanks
Old Apr 16, 2011 | 05:18 AM
drewhall07's Avatar
Default Re: balance shaft/engine rebuild question
if i remember correctly. u gotta take the oil pan, oil pimp, water pump and stuff off to get to it.
Old Apr 16, 2011 | 05:31 AM
usdmftw's Avatar
yes i have the block tore down. i pulled the balance shaft out but the gear on the end has 12mm bolt i took out the tried pulling out. the gear has come about half way off but just dont know if i got it right. is there a cb7 helms in pdf format around here? thanks for the help
Old Apr 16, 2011 | 11:02 AM
chikin pickle's Avatar
Yes that bolt is the only thing holding the gear on. Just work it off and have patience. It sucks, nut thats how to works.
Here is what's up with re-using crank/pistons/rods or whatever.
You NEED a manual and you NEED to take measurements. Make sure all the clearances are within specification.
Also, use the correct bearings. Don't forget the balance shafts have bearings as well (they need to be pressed in/out at a machine shop.)
Prelude Type O
Apr 5, 2018 10:01 AM
eric416
May 4, 2006 12:55 PM
adictionbass
Jan 29, 2005 05:50 PM
model x
May 30, 2004 04:00 PM
ludesleep
Jul 22, 2003 07:58 PM
