Accord F20A4 - Engine quivers at acceleration at low RPM
Old Apr 16, 2011 | 12:21 AM
el_espiritu's Avatar
Default Accord F20A4 - Engine quivers at acceleration at low RPM
Hi,
I'm wondering if my quivering engine (Accord 4G, 1991) run results only from the EGR problem I read in the tech area. The symptons seems to be very likely as described there, although I have MT and not AT. (The engine F20A4 is very comparable to the F22 I think, except the capacity). Is there any other thing I can check? Last year I already cleaned the whole throttle body unit, without any improvements
Besides this, I have the problem that the engine bucks if you take away the gas at low RPM, and it bucks again if you start stepping on it slightly. What can be the cause of this?
Thanks for your answers!
Old Apr 16, 2011 | 11:48 PM
Default Re: Accord F20A4 - Engine quivers at acceleration at low RPM
Nobody an idea...?
Old Apr 17, 2011 | 07:02 AM
poorman212's Avatar
Start with the egr ports. Are the normal tune up items up to date.
Any stored codes from the ECU?
Old Apr 17, 2011 | 07:56 AM
lazlong's Avatar
A quivering and bucking engine sounds like bad motor mount(s).
Old Apr 17, 2011 | 11:25 AM
Air Filter, sparks, distributercap are almost New, Not really bad. Ok, i will try the EGR thing.
joecar
Aug 21, 2012 06:52 PM
mr0lg
Jul 28, 2011 04:54 PM
Ltd4all
Classic Hondas
Aug 1, 2010 05:01 AM
