Car won't start
Old Apr 15, 2011 | 08:25 PM
duscar's Avatar
Default Car won't start
Everynow and then I'll get into my car and try to start it, but it just clicks and wont actually crank. The battery has power so that's not the issue. But after I sit for a few minutes and keep trying it, eventually it will start. Any idea what the issue could be? It's pretty annoying to have to sit until my car wants to start.
Thanks.
Old Apr 15, 2011 | 09:11 PM
spec22's Avatar
Default Re: Car won't start
I couldnt say for sure what it is. I know the main relay in my crx would prevent me from starting it when it was hot outside. I notice your from texas as well lol so this may be the case for you as well. What type of car are you having trouble with? Have any check engines codes? sometimes when your having a problem the code won't even show up on the dash. It's best to have the codes read because the ecu may have some pending and this might save you a **** ton of time. Sorry I couldn't be more specific with out more details about the car.
Old Apr 15, 2011 | 09:45 PM
cherryB-16a's Avatar
maybe you should have your alternator checked or even your starter. i used to have an old ef si and it would turn on, but it wouldn't crank...if i remember correctly it was starter problem. But it's only personal experiences good luck man.
Old Apr 17, 2011 | 04:48 PM
donthatethetegs's Avatar
I agree with cherryb. Sounds like the the starter not popping out and spinning that flywheel. I say replace that starter. You can get your battery checked to make sure it still puts out the right amount of cold cranking amps. If it does my bet is the starter.
Old Apr 17, 2011 | 04:52 PM
el crapitan's Avatar
the fact that it "clicks" means the solenoid is receiving power. i'd replace the starter before it gives you anymore grief
Old Apr 17, 2011 | 04:57 PM
mark@silbernage's Avatar
You may be on the right track but before you start spending money for parts, use a voltmeter and your eyes to do some diagnostics.
Put a full charge on the battery (got a charger? trickle chargers are cheap).
You should see about 12.6VDC on the battery when it's fully charged, before you turn on the key.
Check the battery cables, that they're snug and not corroded. If there's doubt, take them off, dip them in warm water with a couple of tablespoons of baking soda, then clean up the terminals on the battery with a battery tool, sandpaper, file, or scrape them with a knife (etc) so that it's clean metal-on-metal. Reinstall and tighten everything.
Double check where the ground cable from the battery connects to the frame, and also the ground from fender to transmission. It carries much of the current to turn the starter.
If you can get it going, and have a healthy alternator, you should see about 13.8VDC at a fast idle...
Mark
Old Apr 17, 2011 | 05:03 PM
absolutely. check the main ground and battery connections
Old Apr 19, 2011 | 05:51 AM
duscar's Avatar
Turned out to be the starter. Thanks guys.
F20b97AccordLx
Jan 16, 2023 10:15 AM
ED8REX
May 17, 2006 02:06 AM
markchans
Dec 21, 2005 11:43 AM
EG_93Civic
Mar 18, 2005 10:10 PM
patastinky
Sep 4, 2002 06:51 PM
