Knock coming from?
Old Apr 15, 2011 | 05:06 PM
3Rd_gEn_LuDE's Avatar
Default Knock coming from?
Well I'm almost out of ideas trying to figure out wtf is knocking. My suspension was shot everything I've repaired/replaced in the last 6 months:
Rack and pinion New
Tie rods New
Shocks/springs Tokico blues/s tech springs New
Driver Side upper and lower control arms. New
Driver Side Lower ball joint New
Radius Rod bushings New
Driver side Axle New
New tires
Godspeed camber kit
New brakes/rotors.
So I thought My front lca bushing was shot b/c while I was changing out my last axle, I moved it up and down and heard a similar click/knock. But after replacing the whole arm(It was roughly the same price to press in bushings) it still knocked. My sway bar endlinks? look pretty worn. I heard they can be the cause of a knock.
When I'm cruising it does not knock. But when I go over speed bumps or accelerate slowly it knocks.
Any idears fellas?
Old Apr 15, 2011 | 05:42 PM
D16SiHatch's Avatar
Default Re: Knock coming from?
mine did something very similar to this when the radius rod wasn't tight enough where it connects at the lca.
Old Apr 21, 2011 | 03:51 PM
424racer's Avatar
hows your motor mounts?
see if the rear mount bracket is loose.
jonyi27
Mar 23, 2014 07:59 AM
93grayeg
Dec 7, 2012 06:16 AM
swizz977
Jul 5, 2010 06:16 AM
satsilprelude
Dec 10, 2006 11:38 AM
teg92
28
Mar 2, 2006 04:38 AM
