omni camber kit wit Ingalls Alignment Kit together
hey is it possible two camber kit together?Ingalls Alignment Kit and omni camber kit together ? the omni arm with the ingalls two hooks thing not the ball joint..
well with my brother car he has a brandnew skunk2 full coilover with integra arms and omni camber kit and get alightment done 2 time a year bcuz when he hit a big bump it mess up his toe but his car still got like neg 1 or neg 2 camber what i wanted to know if omni upper arm with the two ingalls upper ball where the camber kit goes into the car well it work
OP is asking if Ingalls-type camber adjusters (replaces the bolts on the UCA's) can be used in conjunction with a complete upper A-arm replacement camber kit such as from Skunk2 or OmniPower.
IMHO this sounds like a pretty weak setup. You have lots of sliding parts (both bolts, the ball joint and each bolt holding it), any of which can slide out of adjustment if you hit a large bump or dip.
Also with the Ingalls-type setup, I've heard it's fairly difficult to adjust those and keep each bolt on each UCA straight such that bushings don't bind up and caster doesn't get all out of whack. Not to mention with both kits combined you'll likely end up with serious clearance issues. The UCA may not even fit at all inside the shock tower, which would make it unusable.
So the answer is very likely no, it would not work at all, due to limited clearance under the shock tower.
oh ok well i was just wondering because omni is like i think -+ 4 degree and if i add ingalls kit it will add another -+3 degree.. just a thought..
