Battery draining down
I got some good info from this site regarding a battery draining down but after going through those checks I cannot find the issue. I put the test light between the neg cable and post and sure enough the light lit up. I then started pulling fuses one at a time to find the offending circuit. The light never changed after all the fuses had been pulled. I hear no mechanical click like a stuck relay or seatbelt sensor. Alternator charges. Where else can I look?
The car has a ZC DOHC 1.6 conversion that was done a few years ago.
Thanks,
Thanks,
Not sure this is the case. But any time we have a car that has a draw on it. We check aftermarket cd players. Lot of times you find a nice hack job for splicing the stereo in and keeping a constant power wire hooked up. Just a suggestion. Hope it helps.
Just to update, the stereo checked out fine. What did fail was the alternator. I was drawing 3.5amps on the multimeter when I removed the alternator wire in the under hood fuse box and and it dropped to .39. I believe we found a winner! After working for several hours to get the alternator out (Dropping the driver side motor mount, lowering the steering rack subframe and taking the lower shock mount loose ) Anyway, I got it tested and it had bad bearings for one and a bad diode. Rebuild is underway. Now what was the order in which all this stuff came out?
Thanks
Thanks
ONE*SICK*FERIO
Oct 12, 2009 06:03 PM
bgcrx
10
Jun 2, 2007 09:03 PM
