gsr trans weird noise help!!!
Old Apr 14, 2011 | 03:28 PM
flipldls's Avatar
Default gsr trans weird noise help!!!
narrowing down the noise (clunking/clicking) it seems to be loudest near the starter. My assumption would be either the starter isnt hooked up correctly or speed vss was not put correctly in because my speedometer isn't work. any ideas what it may be, if it is my vss is there a proper way to put it back in rather than just popping it back in.
Old Apr 15, 2011 | 04:16 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: gsr trans weird noise help!!!
What year is the GSR?
Old Apr 15, 2011 | 04:26 AM
Turbo-LS's Avatar
could be a pressure plate spring in the bell housing or a diff bearing or a series of bearings
Old Apr 15, 2011 | 04:33 AM
flipldls's Avatar
im hoping its not something internal with the trans, but i spun the imput shaft quite a bit beforre putting it in, i didnt hear then. i have a 98 gsr trans and would you guys think its the vss jammed because my speedometer isnt working
Old Apr 16, 2011 | 07:44 AM
Turbo-LS's Avatar
The vss is hard to jam it kinda just pops in easy. It could be a stripped gear on the vss or the speedo gear on the diff but if th grans wasn't in gear when you spun the input shaft you wouldn't know if the diff bearings were bad
Old Apr 16, 2011 | 08:01 AM
flipldls's Avatar
mine didn't pop in easy kinda had to twist and push in to get in, it did feel real snug or kinda jammed when i got it in not sure though. But it makes noise when its in nuetral and you can hear it when you give it some gas on a roll.
Old Apr 16, 2011 | 11:50 AM
Turbo-LS's Avatar
Ok the VSS only gives you the speed of the vehicle. reving the engine in neutral will not change the noise or help you hear a vss gear noise so that tells me its not the vss. If your in neutral not moving and you rev it up and it makes noise its either something to do with the clutch/flywheel assembly or a bad bearing on one of the two shafts inside the transmission. if your in gear and accelerate does the noise get louder with the load on it or is the noise the same as when you just free rev the engine
If your moving and its makign noise in gear or neutral then sounds to me like a bad needle bearing on one or the gears or diff bearings but hard to tell without seeing/hearing the car
Old Apr 16, 2011 | 03:13 PM
flipldls's Avatar
well it seems to be a constant light sound and some time when you shut the engine off you can hear it clearly like three or four clunking/clicking noise slowing down
Old Apr 16, 2011 | 05:42 PM
dc2_saul's Avatar
Might be input shat bearing. Mine is making the same noise.
Old Apr 16, 2011 | 06:26 PM
flipldls's Avatar
are you still driving it, and would you think that would be the cause of my idle being at 2k rpm
Old Apr 17, 2011 | 08:27 AM
dc2_saul's Avatar
I don't know about the idle part, but I still drive mine. I read a guy drove his that way for a year and it affected nothing.
Have you tried messing with your IACV?
Old Apr 17, 2011 | 11:31 AM
flipldls's Avatar
yeah i turned the screw all the way in, i may have not set the timing correct because i was able to drop the idle to 1300-1400 rpms after turning the dizzy all the way forward. so when the weather turns out better im going to check that everything is timed correct.
Old Apr 17, 2011 | 03:47 PM
Turbo-LS's Avatar
Transmission problems won effct idle quality. If it's a light sound it can still be bearings inside the tranny or something inside the bell busing but it's not the vss or diff problem
Old Apr 17, 2011 | 09:40 PM
Scooooter7's Avatar
Is there a cable from the speedo gear to your speedo?? Sounds like a bad cable to me.
Old Apr 18, 2011 | 04:50 PM
flipldls's Avatar
no it plugs right into the wiring harness, i'm going to try taking it out and putting it back in.
Old Apr 18, 2011 | 04:52 PM
flipldls's Avatar
from what it looks like it might be my throw out bearing, or input shaft since the sound stops after i push the clutch down. But i just put a new throw out bearing.
Old Apr 18, 2011 | 06:03 PM
dc2_saul's Avatar
If the noise happens when the clutch is depressed, it's not the throw out bearing. The noise would start when the clutch would be depressed. Might be your input shaft bearing. Or maybe low on fluid. Maybe...
Old Apr 18, 2011 | 06:14 PM
Turbo-LS's Avatar
Inputshaft bearing for sure. The longer you drive it the worse the noise will get. Fix it soon before it damages other bearings
Old Apr 18, 2011 | 07:13 PM
Integra4lyfe069's Avatar
its your isb.
driving on it is annoying but wont dmg nething else.
i recently fixed mine.
Old Apr 19, 2011 | 03:03 AM
Turbo-LS's Avatar
eventually it will damage more bearings. wen the input shaft gets really bad there is movement and puts abnormal wear on the bearing on the othe end of input shaft. also if it comes apart the bearing pieces can tear up the inputshaft seal and other bearings.
Old Apr 19, 2011 | 07:15 PM
flipldls's Avatar
are you sure its not the throw out bearing, because when i put the new one in it did seem to have more play than the one i bought from a store.
Old Apr 20, 2011 | 09:55 AM
JoHnnY LonGHoRn's Avatar
u coulda broke a tooth off the vss they should pop right in there meant to be removed in order to fill the tranny
Old Apr 20, 2011 | 10:44 AM
u fill the tranny via the fill bolt.
its your isb.
the throwout bearing makes noise with clutch peddal pushed in and also in lower gears like 1 and 2 when cruising.
isb makes noise with it just sitting out and idling.
if u need help on fixing this i can get you all diagrams, some videos AND walkthroughs with pivcs and parts/tools needed. just pm me. i did this three times.
eh2_Trav
Transmission & Drivetrain
Oct 28, 2018 07:35 AM
Ryan96GSR
10
Aug 13, 2012 06:26 AM
Hal9000
17
Jan 12, 2009 08:27 PM
kingrace
May 7, 2008 09:07 AM
LOWLIFEHATCH
Dec 27, 2002 06:21 AM
