Questions about Ignition Coil.
Old Apr 14, 2011 | 09:04 AM
ezcape's Avatar
Default Questions about Ignition Coil.
When do you know when the ignition coil is going out/bad? Also what are the common symtoms that are indicating that its bad? Thanks
98 LS non-vtec.
Old Apr 14, 2011 | 09:13 AM
mark@silbernage's Avatar
Default Re: Questions about Ignition Coil.
Besides no spark?
Perhaps codes - misfire..
Erratic failure (works, no work, works), seemingly no pattern - possibly worse when warm.
Old Apr 14, 2011 | 09:42 AM
ezcape's Avatar
My car misfires at times. Drives normally but maybe 20-30 minutes into the drive it starts dieing out. Is there a way to check if its bad by taking it out. Like what signs should i be looking for on the coil itself?
Old Apr 14, 2011 | 12:55 PM
If it's electronics, there's not much to see. If windings are shorted in the coil, you can sometimes see heat damage and charring - so it's more obvious.
Once in a while you'll take off the distributor cap to discover it's started arcing (perhaps too long since service, moisture got in, or the little graphite buttons fall apart) and the rotor and cap just need to be replaced.
How do things look inside? You have to pull the cap and rotor, then pull the cover so you can see the works underneath...
95blackEG
Dec 24, 2008 07:59 PM
chrisdavis6
Feb 4, 2008 05:19 AM
Nerologic
Jan 29, 2007 03:56 PM
SpoolnByYou
Mar 25, 2006 09:10 AM
DredwerkZ
Apr 19, 2004 05:21 AM
