Front Sway anti-roll bars questions
my question is what size sway bar would be best for cornering and all around traction. ive got the 24mm asr swaybar in the rear and pro c coilovers all around. im just concerned about oversteer and am not sure what size front sway bar would give me the best control and less oversteer. also if anyone has an upgraded front antisway bar. i'd like to know how it is?
I doubt you'll be having any oversteer issues unless you lift the throttle or brake mid-corner. What sway bar do you have up front now?
Front = 24mm which should be fine. I would never bother upgrading the front sway bar. If you're experiencing too much oversteer as it is now, I would switch to an OEM ITR 22mm rear bar.
Stock ITR came with 24/22 front/rear bars, so you know that's a good setup.
