hub slides into bearing
Old Apr 13, 2011 | 07:58 PM
Creator's Avatar
Default hub slides into bearing
Ok so I'm doing my front wheel bearings and I'm concerned that the hub is toast. I can slide the hub half way into and out of the new bearing by hand. I would just buy new hubs, but I had an extra knuckle with hub sitting around and carefully hammered the hub out. It produced the same results.
Both hubs are wasted?
Old Apr 14, 2011 | 04:02 AM
tauumie's Avatar
Default Re: hub slides into bearing
hubs n spindle need to be pressed in by a machine. hammering them f*cks them
Old Apr 14, 2011 | 06:03 AM
Creator's Avatar
I'm versed in how to do a wheel bearing and hub(hub gets pressed into the bearing not the spindle). It is not me that damaged it or the hammering. You did not answer my question.
new_climber
13
Jun 5, 2011 08:10 AM
RacerTim
Sep 10, 2010 05:44 PM
kyorishin
10
Apr 22, 2008 07:40 PM
petergriffen
Aug 11, 2006 08:44 PM
Bnjmn
Sep 20, 2005 03:43 PM
