what wheel bearing for 90 civic ex front knuckles
Old Apr 13, 2011 | 06:28 PM
crx_253's Avatar
Default what wheel bearing for 90 civic ex front knuckles
i have front knuckles and the codes are LH3-A and Rh3-a i looked them up and found out they are 90-91 ex knuckles
does anybody know what wheel bearing i should order. a shop owner i talked to said crx/civic si only but i looked up the part numbers and they are the same for dx,hf and si..
pls help me get my ef on the road.. and if you guys know a website with cheap wheel bearings i would greatly appreciate it.
thanks!
Old Apr 13, 2011 | 06:42 PM
Tyson's Avatar
Default Re: what wheel bearing for 90 civic ex front knuckles
those are all the same bearing. so use the same part number.
the hub itself on the EX is the unique part. i dont like to reuse hubs, but you can. they do eventually fail but only under extreme cases, so youll be fine just street driving. the problem is that since theyre unique and discontinued... you gotta use the smaller flanged regular EF hubs as a replacement.
skaternak
14
Oct 16, 2014 05:23 PM
millz
Suspension & Brakes
Jul 25, 2014 11:47 AM
Eggman
Oct 18, 2005 03:56 PM
Jaker
Sep 9, 2002 07:00 PM
