Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
View Poll Results: What was your remedy?
New Thermal Protector
0%
New Resistor for the Power Transistor
0%
Voters: 0. You may not vote on this poll
How did you fix your A/C problem?
Old Apr 13, 2011 | 04:09 PM
soundquest's Avatar
Default How did you fix your A/C problem?
I know this is an old post... but I'd like to take a poll to see how many folks were able to fix their A/C issue by either:
1. Replacing thermal protector (as was the solution in this chap's case)
or
2. Adding 1 ohm resistor to to transistor (as has been the solution in other folks' case)
Appreciate the input!
Old Jun 2, 2011 | 07:01 PM
DeLSoLRo's Avatar
Default Re: How did you fix your A/C problem?
Tomorrow ill be switching the fuses under the dash and grounding the thermal red and blue/white wires to see if any of that fixes it. If not ill be back on here doing some more research.
Old Jun 3, 2011 | 12:32 AM
portaman03's Avatar
AC was blowing hot until I replaced the thermal protector yesterday. Now its ice cold!
timmie124
Dec 21, 2009 01:00 PM
theeogflip
May 4, 2008 08:23 AM
BlackYoshi
Jul 11, 2007 06:46 AM
H23BULLET
Jun 10, 2007 05:58 PM
ShinsenTuner
Dec 6, 2006 10:40 AM
