Which year trannsmissions will work for my '94 Ex auto?
Old Apr 13, 2011 | 05:28 PM
denraweb's Avatar
Default Which year trannsmissions will work for my '94 Ex auto?
Trying to find a replacement transmission for my car but don't know which years will work. I have seen 90-97, 94-97, 94-95, etc...
Can anyone lead me in the right direction? Thanks.
Old Apr 13, 2011 | 08:53 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Which year trannsmissions will work for my '94 Ex auto?
For the '94-'97 cars the direct replacement will be based on body type, Coupe/Sedan is one , Wagon is the other. 1-4 gears are the same, the wagon has a slightly lower final drive ratio.
92-96 Prelude will also work, as well as the 95-97 F22 Odyssey, but have lower gear ratios, Prelude uses the lower ratios for better acceleration, Odyssey uses the lower ratios for better mechanical advantage to move it's heavier GVWR.
90-93 Accord will also work, but require a change in the AT stud mount configuration and the transmissions themselves have different gear ratios than the '94-97.
Old Apr 13, 2011 | 10:52 PM
denraweb's Avatar
Oh I guess I should have mentioned lol it's a 4 door. So any 94-97 4 door AT will be a direct replacement? That's what I'm going for. I just want to pull the old tranny, and slap a new one in
Old Apr 14, 2011 | 11:49 AM
MAD_MIKE's Avatar
MM Gruppe B
The Coupe/Sedans use the same transmission, so one out of either of those will be correct(gear ratio). When I picked up a replacement for the '95 EX Japan Engine did not have any Accord transmissions in stock. They had the 'MPJA' which is a Odyssey transmission with lower gear ratios. The cruising rpm is higher than what it was before. 70MPH was ~2700rpm, now its ~3100rpm.
Fitz Williams
Feb 9, 2013 05:35 AM
karrar55
Sep 8, 2011 03:21 PM
wegotmorrison
Aug 15, 2007 05:51 AM
preludeshdriver
Jul 26, 2005 09:10 AM
