Wiring Diagram for ITR ECU?
can anyone refer me to a wiring diagram for a type R ecu? im going to be dropping the B18c5 into my EG, i have everything pulled etc. but the ECU is my main concern right now, any guide for wiring into the EG or just the staight diagram would be very much appreciated, thanks
The engine harness will be plug and play into the Civic. Depending on the year and trim you have, you might need to wire VTEC to the ECU, and wire the O2 sensor.
Just run a chipped P28.
http://technet.ff-squad.com
P.S. You better run better Todd catches you.
