TOO much offset for rear skinnies??
Old Apr 13, 2011 | 04:41 AM
KidFrost's Avatar
Default TOO much offset for rear skinnies??
EDIT: I am only using these on the track..
I know I have seen worst offset on a Civic but IDK if I should run these skinnies..
Worst part is I had these CUSTOM made by Diamond Racing Wheels and this is the best they could do.. I gave them specs on Welds rear skinnies.. IDK.. I dont think they are any worse than these...
http://www.flickr.com/photos/3148919...n/photostream/
Old Apr 13, 2011 | 05:52 AM
JDMBrian's Avatar
Default Re: TOO much offset for rear skinnies??
I don't see any foreseeable issues except the fact that it might rub while the car is squatting.
My friend has some weld skinnies on the rear of his car, that stuck out a little bit. When he ran it, the car's rear tires looked like they were spinning with massive smoke. Due to it rubbing on the fenders...lol He rolled the fenders and solved that problem.
Old Apr 13, 2011 | 08:08 AM
welfarepc's Avatar
nice, gotta love the JJspec single slam teg!
Old Apr 13, 2011 | 09:20 AM
DeLucia's Avatar
If anything I think this would keep the *** end more stable on brakin due to the contact of the two wheels being further apart.
Old Apr 13, 2011 | 09:22 AM
neek175's Avatar
What are the specs on those? I have a set of Diamond racing wheels for my slicks...i just need the skinnies.
Old Apr 13, 2011 | 10:15 AM
KidFrost's Avatar
True I guess..
IDK to be honest with you I talked to Bill@ Diamond and told him what I wanted and he figured it out.. If you want I can give you the number off from them and Bill can look up my specs.. and u can just tell him u want an exact set...
Old Apr 13, 2011 | 11:47 AM
sfwd sentra's Avatar
can u pm me the price and spec
Old Apr 13, 2011 | 02:49 PM
91turbove's Avatar
my old welds on my SE-R were about the same
Old Apr 13, 2011 | 06:29 PM
theidealone's Avatar
Ive got a little more clearance than you, but mine dont rub.
You could also consider a slight amount of negative camber.
Old Apr 14, 2011 | 05:51 AM
KidFrost's Avatar
?? they are not for sale..
Thanks for the input.. I am going to lift the rear some .. about an inch ..inch and a half
Old Apr 14, 2011 | 06:48 AM
neek175's Avatar
What size tire is that? I also was told from a buddy of mine that Diamond only does 4 inch width...I think the Lenso is 3 or 3 1/2.
Old Apr 14, 2011 | 08:43 AM
KidFrost's Avatar
Actually Diamond will only do as skinny as 4.5".. The tire is a 4.5"x15"
Lensos are 3.5"
Old Apr 15, 2011 | 03:38 AM
blakkvtec's Avatar
If You are up to sharing, How much did they cost you? Skinnines seems so expensive for what they are, and everyone wants to know a beater alternative! I have looked into the custom throught cirlce/diamond but never really quoted them.
Thanks
Old Apr 15, 2011 | 06:08 AM
HPgonewild's Avatar
that rear setup looks fat. might as well run some VX wheels.
Old Apr 15, 2011 | 10:36 AM
welfarepc's Avatar
VX's w/ 155's @ 50psi works pretty decent! but its still weight...
steronz
Dec 20, 2010 06:44 PM
Azcheron
Honda S2000
41
Mar 5, 2009 10:00 PM
Hiroshima_VTi-S
Honda S2000
Oct 10, 2007 11:26 AM
DruWO
Jan 25, 2006 05:45 PM
