'99 Accord -- moon roof lubrication?
Old Apr 12, 2011 | 11:33 PM
HondaRob76's Avatar
Default '99 Accord -- moon roof lubrication?
Curious if there's a maintenance manual that indicates lube points for the moonroof/sunroof? It seems to be rather slow these days and sounds like the motor is stressing to move it. I'm guessing I either have a motor about to go out or, hopefully, just need to lube up the slide mechanism somehow.
Old Apr 13, 2011 | 01:17 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: '99 Accord -- moon roof lubrication?
Yes you want to lubricate the slides. lithium grease, silicone,l or any number of lubricants used for this purpose is acceptable.
Old Apr 13, 2011 | 02:58 PM
HondaRob76's Avatar
@DCFIVER - Thanks for the info. Any particular method or just open it up and slather it on?
PS - hilarious sig
Old Apr 14, 2011 | 10:30 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
PS - hilarious sig
Yeah just use you fingertip to put it on. A little is all you need.
Old Apr 14, 2011 | 10:39 AM
Heat's Avatar
Fingertip or a Q-tip.
If you don't have the lubricant, pick up a tube of Shin-Etzu industrial strength silicone grease from the Honda Dealer. Will be about $15 for a toothpaste sized tube of it.
Also use this in your window tracks (the rubber part) to keep your windows going smoothly. Use Q-tips and soapy water to clean the tracks (the exposed part, no need to take the door apart) then more Q-tips to rub down the inside of the tracks with the grease (I also have a '99 Accord, though no moonroof).
Old Apr 16, 2011 | 07:45 AM
WilloughbyCoupe's Avatar
I use a similar technique but I prefer isopropyl alcohol to remove old lube/grime. Coffee stir sticks or popsicle sticks with a little piece of t-shirt fabric work as well (just a preference ). I keep silicone spray on hand for lots of things, works well, as it doesn't seem to attact dirt and grime as much as grease does.
Old Apr 16, 2011 | 07:23 PM
Blamm!!'s Avatar
in the owners manual it says your supposed to lube the door and trunk weatherstripping/sills too. When the doors start getting suctioned shut I use spray silicone.
KellyKoning
Transmission & Drivetrain
Feb 8, 2016 10:27 AM
