car wont start
Old Apr 12, 2011 | 08:20 PM
Lowriderman's Avatar
Default car wont start
I have a 1992 Honda Civic lx. The car has spark and just put a new fuel pump in and that didnt help and also i put a new main relay in. The check engine light isnt on . Just wondering if anyone has had this issue or think they have an idea of whats wrong. Thanks.
Old Apr 12, 2011 | 08:35 PM
Si Hatch97's Avatar
Default Re: car wont start
if the car turns over pull the throtle wide and pour half a shot glass of gasoline into it and take a towl and make it wet with gasoline and hold it on there and have someone start it at half throttle so it can breathe in the gas.
Old Apr 12, 2011 | 08:41 PM
Firebirda7x's Avatar
Does it turn over but not start? no turn over? Is the spark weak and not just existent? Have you checked fuel pressure?
Old Apr 12, 2011 | 08:42 PM
Former User's Avatar
Does the fuel pump prime?
Does the CEL work?
Is spark bright white at the plugs?
Old Apr 12, 2011 | 08:43 PM
EJ8Metal's Avatar
Very vague. It could be a lot of things really. It could be something really simple like a clogged fuel filter to the fuel mapping not telling the injectors to spray.
I'm willing to guess it's something fuel related if you say it has spark. Have you looked into if fuel is getting to the cylinder? Crank it a little bit and pop the plugs out and see if there is raw fuel. (I hate to sound like a Mr. Obvious but you know, have to cover bases.)
Old Apr 18, 2011 | 06:17 AM
I have not check fuel pressure because i do not have a guage but i ruled out the fuel pump because i sprayed starter fluid in the intake. the check engine light does work because once in a while it would come on when driving it, the injectors r working because i put a screw driver up to them and listen to them click. fuel filter is 4 months old. I have tried the coil in the car and another coil that was on a distributor that originally came on the car. I am puzzled
Old Apr 18, 2011 | 07:10 AM
frankenghia's Avatar
what is the cel for when it comes on when driving? What code?
PuFFIN420
Jun 10, 2014 08:38 PM
bpotter05
56
May 15, 2012 01:02 PM
boosted423
Aug 4, 2008 08:20 PM
bri1998
Jan 8, 2008 09:18 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
