alternator help!
Old Apr 12, 2011 | 08:01 PM
sloEFhatch's Avatar
Default alternator help!
i have a 91 EF with a B16A2 swap. i'm having trouble with the alternator charging. i put a new one, it lasts for about 3-4 days then stops charging again. any help would be great!
Old Apr 13, 2011 | 12:57 AM
hatchet_honda's Avatar
Default Re: alternator help!
what engine harness do you have? your not trying to use an obd2 alt. right?
Old Apr 13, 2011 | 04:51 AM
sloEFhatch's Avatar
It's a obd0 harness with a 91 integra alt. Obd0 ECM. It seems like when I turn the headlights on it burns up the alt.
Old Apr 13, 2011 | 09:39 AM
sooo you have an obd2 motor running on an obd0 b series ecu? did you convert to obd1?
Old Apr 13, 2011 | 10:11 AM
sloEFhatch's Avatar
I didn't build the car. I was told it could be a grounding issue. The battery is relocated to the rear. I know it's an obd0 harness and ECM...
Old Apr 13, 2011 | 10:20 AM
4drEF's Avatar
Keyboard Humorist
Is the car ever hard to start?
When you do a relocation kit the alternator has to work a bit harder to charge the battery all the way in the back of the car.
Any idea what gauge power wire you have? Making sure the grounds are in great condition might help too.
But first, I would get a voltmeter and see how many volts you have one the battery with the car off. It should be about 12. Then start the car and see how many volts you have - if it's 14 then your alternator is running. Try a different battery and see if that fixes the problem. If not, check power and grounds.
Old Apr 13, 2011 | 10:23 AM
4drEF's Avatar
Keyboard Humorist
I'm puzzled. Why does this matter?
He could be running an OBD0 PR3.
Regardless, what does this have to do with his alternator? His 91 alternator should run fine regardless if he has an OBD0 or OBD1 ECU.
Old Apr 13, 2011 | 11:00 AM
sloEFhatch's Avatar
The battery is at 12 volts and when I put a new the new alt on it was putting out 14 at idle. After about 3-4 days it burned out.
Old Apr 13, 2011 | 12:56 PM
4drEF's Avatar
Keyboard Humorist
It shouldn't be running at 14v if your battery is at 12.
Try a different battery - could be your battery is tripping out.
If you still get 14v then I would consider your wiring to be the issue.
Old Apr 13, 2011 | 01:04 PM
Nooch's Avatar
Whats the gauge running towards your battery? I've seen and heard of idiots putting 12 gauge on it and it basically not even starting.
Old Apr 13, 2011 | 02:42 PM
sloEFhatch's Avatar
It's like 4 or 2 gauge...when I first put the alt on the meter read AT THE BATTERY 14 volts. If I kill the car it goes to 12.5. Does the battery series make a difference??
Old Apr 13, 2011 | 04:38 PM
sloEFhatch's Avatar
Ok just got home. Started it, turned the lights on, radio on...held fine at 14. Ran for about 5-10 mins (warmed up) and then I turned the blower on. Dropped to 13.5 then stopped putting out. Think it could be over loading the alternator?
Old Apr 14, 2011 | 08:06 AM
4drEF's Avatar
Keyboard Humorist
There is a big problem if your alternator is at 14v (charging) while the battery doesn't need a charge (12v).
It means that your alternator is going to burn out from being in use when it shouldn't be.
Were you able to to try a different battery?
Old Apr 14, 2011 | 08:32 AM
just wondering what were dealing with here..trying to get an idea what his wiring may look like. i realize the ecu has nothing to do with charging system
Old Apr 14, 2011 | 08:34 AM
shoulda figured the issue was from the previous owner working on the car...my guess is that the battery relocation was done pretty crappy....
Old Apr 14, 2011 | 10:00 AM
sloEFhatch's Avatar
I'm having a Honda tech come take a better look at it this weekend. I see the last guy did a hack job on the harness, I'm sure it's a bad connection.
Old Apr 14, 2011 | 10:10 AM
d15b7inEF's Avatar
It so hard to help with these kind of problems unless we are there. Hopefully the tech figures it out my bet is a hot wire is grounding out. and burning up the alternator.
Old Apr 14, 2011 | 10:14 AM
sloEFhatch's Avatar
Yea I know what u mean. It's just so weird that it stops charging when it warms up.
Beeeeightteenc
Dec 2, 2015 02:27 PM
Monstarrr*
Jul 25, 2010 12:26 PM
xxbvanxx
May 18, 2010 11:25 PM
mario_pic
Apr 24, 2008 11:06 PM
