b20 ef hatch swap engine harness help
Old Apr 12, 2011 | 02:11 PM
ej1252's Avatar
Default b20 ef hatch swap engine harness help
first time ever doing a b20 swap into a ef. its for a friends car. i got pretty much everything in except for the engine harness problem. we picked up a 90-91 harness. everythings pretty much plugs up except the one that connects from the engine bay to the ecu. like one of the clip fits but the other dont. i like to know what am i suppose to do? (theres a PIC if you scroll down)
THE SET UP:
integra da axles & halfshaft
innovative steel mounts (hydro tranny)
hasport cable to hydro conversion kit
ls intake manifold
90-91 engine harness
integra da spindles
jdm gsr tranny
b20b4 longblock
custom shift linkage
rywire obd0 to obd2 alternator conversion
rywire obd0 to obd1 distributor conversion
rywire obd0 to obd1 harness conversion
p75 obd1 ecu
Old Apr 12, 2011 | 02:15 PM
staatsper4mance's Avatar
Default Re: b20 ef hatch swap engine harness help
you HAVE to use the harness that goes to the car.....not one for the engine or one from an acura integra
Old Apr 12, 2011 | 02:19 PM
ej1252's Avatar
the stock one doesnt plug up most of the sensors. and its a dpmfi engine harness
Old Apr 12, 2011 | 06:18 PM
tonythetuner®'s Avatar
You use the dpfi engine harness and convert it to mpfi and then it all plugs right in! Check my sig. For my right up for doing the wiring
Old Apr 13, 2011 | 01:07 AM
hatchet_honda's Avatar
man you bought alot of rywire shizz...wayy easier to depin the plugs you already have. the ecu harness is a must tho. okay you have to use the dpfi engine harness that goes to this car. add 4 wires and convert it to mpfi. theeeen add plugs as needed to fit the b20. ya feel me? ya know like lengthen the fan switch wire and put an obd1 plug on the harness side. add your 4 wire o2 wiring...aaand so on
Old Apr 13, 2011 | 01:13 AM
ej1252's Avatar
nice write. appreciate it.
Old Apr 13, 2011 | 01:47 AM
crx_si-r's Avatar
you do realize that the obd0 to obd1 alternator jumper was plain useless. especially since obd0 and obd1 alternators are a direct plug n play set up. they have the exact same plug.
Old Apr 13, 2011 | 11:45 AM
ej1252's Avatar
my fault..meant its a obd0 to obd2 jumper
alternator is obd2
Old Apr 13, 2011 | 12:19 PM
crx_si-r's Avatar
You would still nee to convert to mpfi
Old Jul 7, 2012 | 07:00 PM
91efmatt's Avatar
hey i was just wondering i got a ef hach shell off my cousin and it needs a new harness and i want to put a b20 in it would it just be easier to put a mpfi hanress in it ts already been swapp to a b series but i just got a b20 and was wondering im new to honda but i know i need the axels and everything but the harness is bad so i need help its a 91 ef what can i do
Old Jul 7, 2012 | 08:19 PM
crx_si-r's Avatar
if the car is properly converted, then usethe harness that came with the car. if the harness is missing, get a harness that matches the car and convert
Old Jul 8, 2012 | 04:54 PM
91efmatt's Avatar
i cant use the harness the harness is fried so what should i do get a si harness for my year or what
Old Jul 8, 2012 | 05:56 PM
Mr.Cheezil's Avatar
no, you will have to source another dpfi harness and convert it to mpfi.
Old Jul 8, 2012 | 07:45 PM
91efmatt's Avatar
why cant i just get a mpfi harness
Old Jul 8, 2012 | 08:10 PM
Mr.Cheezil's Avatar
it wont work with the chassis harness.
i have a b20b in my 4 door dx which was previously dpfi, converted my harness to mpfi and converted the b20 to OBD0 with ls components and am running a pr4 ls ecu. not a single problem...
Old Jul 8, 2012 | 08:18 PM
91efmatt's Avatar
how would i do the dpfi to mpfi im not good with electric work and dont really have patience
Old Jul 9, 2012 | 08:17 AM
91 EF DX's Avatar
If you can't do the conversion yourself you can always buy a conversion harness
Old Jul 9, 2012 | 12:27 PM
crx_si-r's Avatar
pm me
Old Jul 9, 2012 | 12:29 PM
91efmatt's Avatar
whats the harness called
Old Jul 9, 2012 | 12:33 PM
91 EF DX's Avatar
DPFI TO MPFI CONVERSION HARNESS
Old May 23, 2014 | 10:05 PM
Buddha214's Avatar
I got a sedan shell no cabin harness or no wiring so I got a complete si harness fromel under the dash to my headlights an motor harness can I u se that or is it not a option my sedan is a 89 an so was the si I got it from
Old May 23, 2014 | 11:26 PM
codybuRr's Avatar
that engine harness looks cut or something..
Old Jan 21, 2018 | 02:55 PM
Chris Deters's Avatar
Icon5 Re: b20 ef hatch swap engine harness help
You have picture or wiring diagram for ecu I have po6 with jumper harness I have wires not sure where went or go. The car ran great now starts up and dies. But stays running if spray has in intake it’s a B20b swap ef sedan
CRXLST
Jul 24, 2013 11:51 PM
0ne-Cam
Jun 30, 2013 07:39 PM
91efbluehatch
12
Apr 3, 2011 12:19 PM
0ne-Cam
Sep 25, 2009 08:42 AM
apice
Mar 19, 2008 03:35 PM
