b series idling problem
Old Apr 12, 2011 | 02:06 PM
gnxpro24's Avatar
Default b series idling problem
just started up my b18a1 and the idle is around 3500 and climbs to about 4000. what could be the problem? the air hole in front of the throttle plate is pulling air, if I block it it drops 1000 rpms but still idles near 3000. also the plate is fully closed
Old Apr 12, 2011 | 03:25 PM
ascarberry's Avatar
Default Re: b series idling problem
its getting air from somewhere to idle that high check your vacuum lines etc! does it drop to 1000rpm and stay or jump back to 3000?
Old Apr 12, 2011 | 03:44 PM
gnxpro24's Avatar
its starts at 3500 then climbs to about 4200 and stays around there. if I block that hole tat goes to the fitv, it goes to about 2500-2700
Old Apr 12, 2011 | 03:58 PM
4drEF's Avatar
Keyboard Humorist
What is you loosen or remove your accelerator cable?
Old Apr 13, 2011 | 09:50 PM
gnxpro24's Avatar
cleaned the iacv and fixed the fitv but still idles at 2500-2800
Old Apr 15, 2011 | 04:40 AM
gnxpro24's Avatar
20vt_gtx
14
Dec 27, 2019 04:50 AM
stuckinmud
Jul 23, 2009 06:01 PM
JRG151
Dec 11, 2007 11:58 PM
leonard1818
Nov 23, 2005 12:12 PM
