FS/FT: Integra Type R. 433whp+
Contact: PM, I check here twice a day.
Price: $16,000 (Cutting my lost)
Trades: MAY ACCEPT Clean GPW S2000, STI, RSX or Shoot offers, I'm not gonna be an ******* and the worst I can say is "no", so don't be afraid.
I have a 1998 Integra Type R, Fully built making 433whp on 14psi (Lowboost;off the wg). Only has 3k miles on the FRESH build & everything was bought BRAND NEW. All work done to the car was done while I owned it and was PROFESSIONALLY done @ SpeedFactory(motor build, fabrication, tune, & labor was done there).SpeedFactory is a very reputable shop and is known all over the U.S which also hold records. (www.SpeedFactoryRacing.net)... Over 24k into the car (including the car itself).
Link to a Dyno contest @ a Local Honda-Tech Meet on May 1, 2010
Car won most WHP car. Made 416WHP on 13psi
SPECS :
1998 Integra Type R
Championship White
Fully built JDM ITR (B18C) Boosted
80,xxx On Chassis
Almost 3k on the fresh build
433 WHP on 14 PSI Pump Gas (Low boost; Off the wastegate)
Interior: 9/10
Exterior: 9/10
This car is in AMAZING condition & EXTREMELY fast.
Car is built RIGHT.
Engine:
Has P/S
Motor was Sent to Machine shop for: Bore, Hone, Micropolish Crank, Deck Block, sprayed.
B18C-R Almost 3k miles
Eagle Rods
CP Pistons
Rage B Series Cam Gears
Blox B Cams
Supertech Titanium Retainers
Supertech Dual Valve Springs
Goldeneagle Headstuds
ACL Rod Bearings
ACL Thrust Washers
ACL Main Bearings
NEW OEM Timing Belt
New OEM Water Pump
NEW OEM Thermostat
NEW OEM Headgasket
NEW OEM Starter
New OEM Gaskets for anything you can think of.
Energy Suspension Motor Mount Kit
Goldeneagle MFG Oil Squiter plugs
Golden Eagle Cam Seal
AEM Fuel Rail
Spoon plug wires
NEW NGKBkr7e Spark Plugs
SpeedFactory HalfSize Aluminum Radiator
Drivetrain:
ITR Tranny w/ LSD
New ACT clutch
New Act Extreme Pressure plate
Literally Shifts like butter
Turbo Setup:
SpeedFactory Top Mount Manifold
Tial 44mm Wastgate
Brand New Greddy Type S BOV
SpeedFactory Aluminum intercooler Piping
SpeedFactory 3" Stainless Steel Downpipe & Dumptube
Full StainlessSteel 3" exhaust with Apexi wsp 3in Universal muffler
Garret 57 Trim .63 AR
XRP Oil FeedLine, SS Braided Race Hose,
SpeedFactory Custom Catch Can
Brand New 750HP Intercooler
Greddy Profec B Spec 2 B/C
Fueling:
OmniPower 4 bar map sensor
Injector Dynamics 1000cc Saturated Fuel Injectors
Walbro HP255
Exterior:
OEM JDM HID front end [all metal]
Seibon Oem style carbon fiber hood
Spoon Carbonfiber lip just [re cleared]
Optional Side Skirts
Optional Rear Valances
Antenna block off
Red Benen Front/Rear Tow hooks
Interior:
FULL OEM ITR INTERIOR
Jdm ITR steering wheel SRS
Skunk2 shift ****
J's racing Floor Bar
Itr cdm floor mats
Jdm ITR REAR seats [1 piece bottoms]
Wheels/Suspension:
J's Racing Fender Brace
Brembo slotted rotors
JIC magic front lower tie bar
J's racing sub frame brace
Function 7's LCA
Professionally Powdercoated 15' ITR wheels with BRAND new Hancooks
Audio:
Pioneer In dash touch screen dvd player
infinity speakers all around
Professionally Wired up for Amp/Subs
PICS:
My bandwidth exceeded its limit so for now, you'll have to click on this link to view pictures.
http://s395.photobucket.com/albums/pp32/MyBlackSi/
Many pics during the build:
SPECS :
1998 Integra Type R
Championship White
80,xxx On Chassis
Interior: 9/10
Exterior: 9/10
Car is built RIGHT.
Engine:
Has P/S
Eagle Rods
CP Pistons
Blox B Cams
ACL Rod Bearings
ACL Thrust Washers
ACL Main Bearings
NEW OEM Timing Belt
New OEM Water Pump
NEW OEM Thermostat
NEW OEM Headgasket
NEW OEM Starter
AEM Fuel Rail
Spoon plug wires
Drivetrain:
ITR Tranny w/ LSD
New ACT clutch
Turbo Setup:
Tial 44mm Wastgate
Fueling:
Walbro HP255
Exterior:
Antenna block off
Interior:
Skunk2 shift ****
Itr cdm floor mats
Wheels/Suspension:
Function 7's LCA
Audio:
PICS:
interested in a car I had built at the speedfactory? about the same money all around as yours. Just a different car to drive. went 450whp, cert'd moly cage. 5.9 axles, best of everything, street legal. Just put a wad of money into having the Speedfactory put all new synchros in the transmission. I'd call the transmission, basically new. Pretty rare in and of itself.
No drama, just a crazy fast street car, built by the best.
some extra pics:
some extra pics:
