Coolant loss
Old Apr 12, 2011 | 01:37 PM
Pure Sol's Avatar
Default Coolant loss
94 accord EX is losing coolant at the rate of a quarter gallon every 2 weeks. No visable signs on the ground or in the engine bay. Radiator cap looks like it has seen better days so I ordered one and it is on the way. Any other ideas where to look?
Old Apr 12, 2011 | 01:48 PM
StreetsideStig's Avatar
Default Re: Coolant loss
Do you get alot of white, sweet-smelling smoke? It could be burning it due to a leaky head gasket or something. Is it running hot?
Old Apr 12, 2011 | 01:59 PM
h22_cb7's Avatar
yea it kinda sounds like the head gasket is goin bad, maybe take a look under the car on the driver side and look at the water pump and see if theres a little bit of water coming from the weep hole. hope you can figure it out.
Old Apr 12, 2011 | 03:10 PM
zorobabel's Avatar
Does it smell like coolant in the engine bay or in the cabin, when running or afterwards?
If not it might be the head gasket.
Old Apr 12, 2011 | 03:51 PM
Pure Sol's Avatar
No white smoke or sweet smell, the headgasket and water pump was done less that 10,000 miles ago but will check that out just to be sure. Will update as soon as I get a look at it.
Old Apr 14, 2011 | 05:26 PM
Pure Sol's Avatar
Crawled under it today and didn't see anything from the weep hole. Any other ideas before the headgasket?
Old Apr 14, 2011 | 10:50 PM
holmesnmanny's Avatar
Pull the spark plugs and see if they look similar to the color of your coolant with hard deposits on them. If so, the deposits are coming from somewhere and it aint the fuel system.
turbols99
Feb 5, 2007 07:28 PM
Racermech
Jan 19, 2007 07:30 AM
Gumbey75
Feb 23, 2005 04:08 PM
drdavidge
Dec 29, 2002 04:25 PM
whagkangmakulet
Sep 23, 2002 06:43 AM
