Alignment changes when you drop/raise the car with coilovers?
Old Sep 28, 2002 | 09:23 AM
EL'ation's Avatar
Default Alignment changes when you drop/raise the car with coilovers?
If I get an alignment done today with current height and next day, raise it an inch with coilovers, do I have to get alignment again?
Old Sep 28, 2002 | 09:46 AM
TurboBumblBee's Avatar
Default Re: Alignment changes when you drop/raise the car with coilovers? (EL'ation)
yes
anytime you do anything to your suspension setup its is recommended that you get an alignment..
Old Sep 28, 2002 | 01:11 PM
96 SOHC VTEC's Avatar
Default Re: Alignment changes when you drop/raise the car with coilovers? (95CivicEX)
yes
Well, not necessarily. You can raise it or lower it and not have to get another alignment, but it all depends on how much you adjust it. If you only adjusted it a 1/4 to 1/2 inch, I don't think you would need another alignment. Change it an inch htough, and that is a different story.
tallguy21
Suspension & Brakes
Feb 11, 2013 05:08 PM
jxhxb
Suspension & Brakes
Jan 9, 2009 10:51 AM
ek4d00r
Suspension & Brakes
May 17, 2005 03:40 PM
alex01
Aug 23, 2004 12:12 PM
nijia555
Oct 27, 2002 03:59 AM
