~ 98+ Integra LS B18B1 OBD-II Magnaflow Catalyic Converter + NGK O2 CA Certified $99
I have a new condition Magnaflow Catalytic Converter (Model #46629) and a NGK/NTK OEM O2 sensor (Model #24169) for a 98+ Integra LS with a B18B and OBD-II. These are the direct bolt on parts for 98-01 Integra LS. Both parts are Smogged certified in the state of California.
I'm looking to lend out the cat converter and o2 sensor to those who need to smog their cars. I know it's tough to smog your car legally and it's quite expensive to replace the parts so this is a way to help those out. Retail on the Magnaflow Cat is $1092.29 and the NTK o2 is $79.99
I can ship the cat converter and o2 sensor or if you're in the Bay Area you can pick it up and then drop it off.
Check Engine Code for Bad Catalytic Converter
P0420 - Catalyst System Efficiency Below Threshold
Here's the direct websites:
http://www.magnaflow.com/02catalytic...irectfit=46629
http://www.ngksparkplugs.com/product...sors/index.asp
