Hopefully not another dumb mpfi swap question
I noticed there was a heater hose on the dpfi that runs from the intake near the thermostat to the bottom side of the tb/injection unit. I dont see where to route that large hose from the mpfi? Does the motor come with a different water neck and that nipple go to the heater hose or am I missing something?
If I'm understanding/following what you are saying, you are talking about #6 on the DX/STD (DPFI) side of the diagram. You need #7 on the Si (MPFI) side of the diagram or some sort of rigged substitute. The water neck/thermostat housing is the same but the hose should be a "U" and connect right next to the cylinder #4 intake runner.
No worries
PS
Usually when I need a quick diagram I go to www.thehondapartsstore.com (you can use any similar website). They use exploded diagrams but you have to dig around to find the one you need.
PS
Fo-Do Fanatic
15
Feb 9, 2010 08:37 PM
dem0nk1d
Sep 25, 2006 01:35 PM
