Replacing broken studs, need help.
Old Apr 11, 2011 | 12:01 PM
chevyhonda's Avatar
Default Replacing broken studs, need help.
I drive a '94 Honda Accord Ex. I wont go into detail of what happened, but apparently I ran into a curb and I broke a stud. I broke another trying to loosen a bolt to get to the stud. There's this plate or something in front of the studs, I don't know what its called. I tried to remove it and loosened 3 out of the 4 bolts, but the last bolt is too rounded to get out. What can I do?
Bolts>Tire>Plate>Studs
Old Apr 11, 2011 | 05:26 PM
poorman212's Avatar
Default Re: Replacing broken studs, need help.
Try, memory is bad, removing the caliper. The rotate the hub to get to the stud out and back in.
Old Apr 11, 2011 | 05:29 PM
thapimpfromchi's Avatar
you can get a bolt extractor. they're pretty cheap. Idk where you live but Harbor freight has a set for like 10 bucks. they work wonders.
Old Apr 11, 2011 | 06:52 PM
TheMuffinMan's Avatar
He knows where you live!
I wouldn't call them bolts, they're lug nuts.
The lug nuts hold the wheel to the hub which is the circle thing you're seeing, the hub is over top of the brake rotor.
You need to remove the caliper, then you can see a small gap where if you spin the hub/wheels studs around you can hammer them through. To replace, insert the replacement stud through that same gap, then use a lug nut to tight it down and bring it flush with the others. If you do a search on this section there are several threads regarding the procedure.
Integra4lyfe069
Aug 9, 2009 09:16 PM
jdmh22luda
Aug 3, 2006 01:08 PM
rollercosta123
Mar 10, 2006 08:01 PM
95GSRTT
Apr 30, 2005 05:57 PM
SEA Hag
Jan 9, 2003 06:15 PM
