help: low fuel presure and no start after installing walbro fuel pump.
Old Apr 11, 2011 | 07:35 AM
dannysolis92005's Avatar
Default help: low fuel presure and no start after installing walbro fuel pump.
just installed the walbro 255 kit and getting 20psi( got gauge on fuel filter) itr motor, was getting like 44 psi with stock 91 si fp. now car wont start, it cranks and started once but died out. do i need an adjustable fuel pressure regulator. i followed haynes manual to change it. thanks!
Old Apr 11, 2011 | 07:44 AM
bambam's Avatar
Default Re: help: low fuel presure and no start after installing walbro fuel pump.
What vehicle? What's the fuel level? What exactly did you install?
Was it just the pump? Or did you install other things like the gauge and fpr?
Old Apr 11, 2011 | 08:01 AM
the car is a 91 civic si, fuel level is a bit less that half tank, i installed the the walbro 255lph kit including the sock. installed a fuel pressure gauge before the walbro pump and the stock pupm would read 44 psi. i dont have a fuel presure regulator.
Old Apr 16, 2011 | 01:19 AM
DAMotorsports's Avatar
you dont need a regulator, drop the tank again sounds like u did not do the install correctly or the pump is bad. the other choice is top the tank off and see if the psi goes up. if it does the install was wrong. bad part is the tank is now full.
we have seen car where the pump was not on correctly or the tube was bent/broken and at the half tank it would shut off
Old Apr 16, 2011 | 09:49 AM
fungus mungus's Avatar
^x2. There is no reason you should need an adjustable fuel regulator for that pump. Is this a new or used pump? Did you replace the hoses or reuse the old ones? If you reused the old hoses, are there any cracks in them? Of course, it could just be a bad pump.
fm
sLyBlAzNbBoI
Feb 3, 2009 05:58 AM
94lvstreetscene
Nov 10, 2006 12:55 PM
GS-R Civic
Dec 2, 2005 06:57 PM
SIK IN DA HED
Nov 29, 2002 06:06 PM
Charlie Moua
Sep 6, 2002 12:16 PM
