Car doesnt feel like it is pulling as hard?
Old Sep 28, 2002 | 07:25 AM
OzManB18C1's Avatar
Default Car doesnt feel like it is pulling as hard?
Okay first off I have a 98ek hatch, with a B18C1 with your basic bolt ons. In the past week it doesnt feel like it has been pulling as hard. I need to determine what to look for, I assume it might be a fuel or ignition problem. Is there anything I need to check out. Thanks
Old Sep 28, 2002 | 07:33 AM
PnX-R's Avatar
Default Re: Car doesnt feel like it is pulling as hard? (OzManB18C1)
I would check the spark plugs for proper gap and see if the plugs are brown or not. Next thing I would do is OHM check the plug wires for the proper resistance. YOu should read less than 25,000 ohms.. Hope that helps..
Old Sep 28, 2002 | 07:37 AM
OzManB18C1's Avatar
Default Re: Car doesnt feel like it is pulling as hard? (PnX-R)
thanks for the help. any more ideas would be appreciated
Old Sep 28, 2002 | 08:40 AM
lazy bum shaughn's Avatar
spark plugs, wires, distributor etc.
Old Sep 28, 2002 | 10:51 AM
OzManB18C1's Avatar
Default Re: Car doesnt feel like it is pulling as hard? (Breakdancer)
Old Sep 28, 2002 | 03:10 PM
yaya's Avatar
they have 25,000 ohms of resistance???daymn thats a lot
didnt know that
Old Sep 28, 2002 | 04:03 PM
miahmouse's Avatar
vacuum lines are another thing to look at (i'm thinking of secondaries/iab/butterflies whatever you want to call them). Is it not pulling as hart throughout the power band.....or just at the top??
Old Sep 29, 2002 | 09:56 AM
Bontke's Avatar
Default Re: Car doesnt feel like it is pulling as hard? (miahmouse)
If you are running lean (for what wever reason) your car will loose power. Some things to check would be fuel pump output pressure, injectors could be dirty, fuel filter could be cologging up. Also map sensors will effect fuel delivery.
Old Sep 29, 2002 | 01:49 PM
Shane54's Avatar
I had that probelm a little while ago and it turned out to be the fuel filter. The thing with these kinds of problems is that sometimes you end up changing a bunch of parts that don't need to be changed in order to fix the problem
Old Sep 29, 2002 | 02:33 PM
Bontke's Avatar
Default Re: Car doesnt feel like it is pulling as hard? (Shane54)
If you want to know if the engine is starved for fuel look at the end of the spark plugs. If they are a white color or very light tan, the engine is lean. If it is a natural tan then it is fine. Dark sooty black plugs are signs of too much fuel.
Old Sep 29, 2002 | 06:05 PM
OzManB18C1's Avatar
Default Re: Car doesnt feel like it is pulling as hard? (Bontke)
Thanks for all the tips, I plan on checking it out tomorrow.
Old Sep 29, 2002 | 08:36 PM
Lsos's Avatar
I had that problem, too.
In fact, that's a problem everyone that adds a turbo, motor, NOS, tires, suspesnion, etc. experiences after a week or two. They then go on to throw down another five grand on engine work to turn up the boost or whatnot....
You sure you didn't just get used to it?
[Modified by Lsos, 5:19 AM 10/1/2002]
Old Sep 29, 2002 | 08:58 PM
brownshigh's Avatar
Default Re: Car doesnt feel like it is pulling as hard? (Lsos)
is it the engine,or jus the car?reason being,if the car revs fine,and idles ok etc., could jus be a laggy break(s).i had that problem once
Old Sep 30, 2002 | 01:42 PM
OzManB18C1's Avatar
Default Re: Car doesnt feel like it is pulling as hard? (brownshigh)
Well I know I am not used to the mods, because I raced one of my firends cars and it pulled on me alot harder than before. I know for a fact he has the exact same setup he has had in previous races, and we did it numerous times so I doubt it was a lucky run.
[Modified by OzManB18C1, 10:43 PM 9/30/2002]
Nick Cronk
Apr 20, 2013 06:14 PM
corys_ej8
Sep 2, 2011 06:12 PM
Westracing33
Oct 20, 2007 10:02 PM
Nighthawk GS-R
Sep 22, 2003 09:52 PM
Trinity
13
Sep 4, 2002 06:01 PM
