Broke Off Valve Cover Bolt off.......need advice
Old Apr 10, 2011 | 06:56 PM
RoadRaceMike's Avatar
Default Broke Off Valve Cover Bolt off.......need advice
Hey everybody.....
so i'm putting my valve cover back on my B20 and i'm tightening down all the nuts and i get to the LAST ONE......the one closest to the dizzy that also holds down that L shaped bracket thingy that holds the spark plug wires and it sheers off flush with the top of the plastic doughnut thingy that sits in between the nut and the valve cover.....
somebody please tell me that crankcase pressures are low enough that i can just live without that one completely. it's the one in the center on the very end. will the super grey i put on the brand new valve cover gasket be enough to hold it?
if not, does anybody have any good ideas on what i should do next...
Mike
Old Apr 10, 2011 | 07:38 PM
Tyla12's Avatar
Default Re: Broke Off Valve Cover Bolt off.......need advice
if im reading this right you broke a valve cover bolt when tighting it? and its stuck in ur head?
i broke one on my single cam and i dosent leak or anything i just got a little rubber gourmet from ace hardware and pushed it in for now tell i fix it haven had any probelems had it thisway for quite some time now.
Old Apr 10, 2011 | 07:41 PM
Frozen E's Avatar
H-T White Ops
Did the same thing you did before. I'm assuming you only busted off the top portion of the stud, and not all the way down in the head. Driving with that hole uncovered is going to make a mess of your engine bay. Put a decent size dab of hondabond or whatever silicone you have over the hole, wait a couple hours and go order yourself a new valve cover stud from Honda (guaranteed they won't have one in stock). You'll be fine without it for a while.
When the stud comes in, pull the valve cover off, get yourself a deep well socket, yank the old stud out. I think it's either a 10 or 12mm like everything else on that damn car. Put the new one in, and stop over tightening those VC nuts.
Old Apr 10, 2011 | 07:44 PM
TaffetaEj6's Avatar
ummm...over tighten much? I did the same thing once on a b16 head. Pressure will not be low enough, you will get oil on the valvecover and underneath your hood. I know cause I drove the car to honda like that. Honda dealer sells them for $6-$8. Just go get one.
Old Apr 10, 2011 | 07:46 PM
Tyla12's Avatar
yeah they are cheap just one of those things you dont wanna do lol.
Old Apr 10, 2011 | 07:50 PM
TaffetaEj6's Avatar
dont know what you mean? You pull the VC off, look at broken stud, grab your 12mm wrench/socket, pull it out, new one in,VC on, just over hand tight. You dont work on your own cars? Not that hard...i would consider replacing your clutch as something you dont wanna do lol.
Old Apr 10, 2011 | 07:52 PM
beautiful advice everyone!.......i have a lapping day this thursday so i'm going to try to get a new stud from the stealership tomorrow!
does anybody know the part number of the post?
Old Apr 10, 2011 | 07:53 PM
TaffetaEj6's Avatar
stealership !
hahaha...so very true my man
Old Apr 10, 2011 | 07:54 PM
Frozen E's Avatar
H-T White Ops
Dealership does.
Or www.hondaautomotiveparts.com
Old Apr 10, 2011 | 07:56 PM
Tyla12's Avatar
mine broke in the head like flush i cant grab it or anything it snaped inside the head not outside where i could twist it back out i have to drill into the head in order to get it out.
Old Apr 10, 2011 | 07:57 PM
lunareg's Avatar
mine did this too, you can use an extractor bit to get it out
Old Apr 10, 2011 | 07:59 PM
Tyla12's Avatar
Good call on that have you had any experience?
Old Apr 10, 2011 | 08:02 PM
TaffetaEj6's Avatar
well thats what you did not the OP but thanks for sharing...jk not being a dick just think your funny
Old Apr 10, 2011 | 08:06 PM
Originally Posted by Frozen E
Dealership does.
oh, no way..........thats deep man.....awesome
Old Apr 10, 2011 | 08:10 PM
Tyla12's Avatar
just noticed ur location going to the tech meet?
Old Apr 10, 2011 | 08:11 PM
TaffetaEj6's Avatar
working, but wish i could...i have burnt all my paid time off
Old Apr 10, 2011 | 08:13 PM
Tyla12's Avatar
Dang no good.
khailon
May 10, 2011 03:51 PM
genetsang
Mar 25, 2004 02:40 PM
genetsang
Mar 25, 2004 02:34 PM
hatchii
Nov 29, 2003 08:07 PM
redteg1
May 21, 2002 02:57 PM
