B16 stroker or B20 ?
Old Apr 10, 2011 | 06:25 PM
zanottivti's Avatar
Default B16 stroker or B20 ?
Hi!
I searched across the forum, and didn't found any topic like this... just "b18" ones, not b16.
So..
I'm building a all motor setup with a B16A2 block with JUN Stroker KIT (1.8).. and talking with some friends, we had a doubt...
What build can make more WHP with the same setup (vtec head, cams, head, intake, exhaust, compression.. ), a B16 stroker or a B20 ?
Some say that the B20 itself has more power, but other say that the B16/18, can get high revs...
What do you guys think about it ?
Thankyou so much!
Edit: I'm sorry, i searched again and found some posts.. you can delete this if you want to.
Old Apr 10, 2011 | 07:29 PM
2k.civic.si's Avatar
Default Re: B16 stroker or B20 ?
displacement wins.
Old Apr 10, 2011 | 07:55 PM
zanottivti's Avatar
Originally Posted by 2k.civic.si
displacement wins.
rev can't replace displacement ?
Old Apr 10, 2011 | 07:58 PM
TaffetaEj6's Avatar
b20 w/ ctr slugs, bolts, bearings...mild built head w/ some s2s2 cams would stomp a 1.8 stroked b16...those kits aren't cheap from jun, could never justify spending that much money on something like that...IMO anyways, but completely up to you
Old Apr 10, 2011 | 09:38 PM
no
there is only 1 replacement for displacement....its called boost.
Old Apr 10, 2011 | 09:48 PM
.Manny.'s Avatar
Touching My Member
B20. Get yourself the "stroker" using OEM parts.
B20 with CTR pistons? GTFO. First, not made in 84+mm. Second, GTFO again.
Old Apr 11, 2011 | 07:29 AM
Red_Army's Avatar
b20 wins all day.
plus if you make a b20vtec you can rev and have displacement if built right.
and you could build the whole engine for the money it'd cost to pick up that stroker.
Old Apr 11, 2011 | 07:47 AM
mvm's Avatar
mvm
lmao
Old Apr 11, 2011 | 01:09 PM
hoffmanb16's Avatar
Exactly.... I was like is this guy serious? Im gonna flame this ***** of of him, then you handled it....
agian G T F O .....
Old Apr 11, 2011 | 03:14 PM
zanottivti's Avatar
no
So..
What about boost the stroker? The pistons and rods are forged.
It haves 11.6:1 compression...
I know that's quite of insane and out of any standards... but, it's too much compression for 10 or 14psi ??
Old Apr 11, 2011 | 03:32 PM
igorka_91's Avatar
b20v with stock rods, arp rod bolts properly fitted. rs machine itr pistons, some bigger cam then a ctr like a s2s2 or pro2. either a vic x IM or a performer X. bigger TB like a 68 or a 70mm. bigger injectors. id use oem rdx 410cc injectors. a b16 or gsr trans. and a good tunning program and a tune from a reputable shop. With that you spent on that jun stroker kit. Im shure you could have half of the above and more. Sorry for the run on sentence. With that i said up above.easy 200whp if ure tunner can tune. Probably close to 220 ~ whp butt hp is just a number. Trap speeds and times is were its all at. If u have a 300 whp b series allmotor running 13.9s. Then the dynno is callibrated way the hell off or you suck at driving.
GL with the build.
Old Apr 11, 2011 | 08:33 PM
lunatics209's Avatar
So..
Please don't waste our time with your dream builds!
Old Apr 11, 2011 | 11:16 PM
igorka_91's Avatar
x2.
ure better of just spraying it then a turbo. much cheaper.
Old Apr 12, 2011 | 03:59 AM
zanottivti's Avatar
Dream builds?
it was just a question man..
i'm sorry if i wasted you precious time.
Old Apr 13, 2011 | 02:00 PM
TaffetaEj6's Avatar
hmmmm....so what, rs machine no longer makes 84mm ctr pistons? I have a friend that bought some from rs machine, or he says...i know they have 84mm itr pistons, maybe i just got confused when he stated he just got 84mm type r pistons...all i know is that car mobs and there are several people on the net w/ the same set-up, w/ itr's that is.
Old Apr 13, 2011 | 02:24 PM
.Manny.'s Avatar
Touching My Member
Just ITRs in the bigger sizes. Oh and I didn't mean to sound like such a *****.
B20 w/ ITRs =
Old Apr 13, 2011 | 03:43 PM
TaffetaEj6's Avatar
B20 w/ ITRs =
thanks manny...im a big boy and can handle people being ******, you really weren't by the way if you really read your comment to me I aint butthurt or nothing. Cheers to your beer
Old Apr 13, 2011 | 04:46 PM
kart_driver's Avatar
filhoooooo, o q eh isso b16 stroker ou b20v ?????
ahhh, pára vai!!!
rauahuahuahauhhu
Old Apr 14, 2011 | 03:57 PM
zanottivti's Avatar
vai zuando ronaldo.
quero ver quando eu der um cacete naquela sua jabiraca véia.
Old Apr 14, 2011 | 06:37 PM
ShaunRR's Avatar
HT White Ops
Community Builder
displacement wins.
threehonda
25
Jan 3, 2010 09:16 AM
bayron
Aug 19, 2008 01:56 PM
adonis2oo2
30
Jan 4, 2007 10:31 PM
K20Z3CivicSiVTEC
Nov 3, 2005 10:28 AM
JDMCRX
10
Jun 22, 2002 06:17 AM
