Clunking/knocking in rear suspension
I have an 05 base rsx and recently i have been hearing this weird clunking or knocking noise anytime i drive, coming from my rear suspension. Iv been searching on crsx but could only get an answer about the rear swaybear bolts being loose, but sway bars fine. i have complete stock suspension. any help would be cool. thanks
check for any torn bushings need to be replaced...i had this same problem and it was the bushings
if the bushings are too worn or torn, they're not stopping the suspension from going down/moving around and hitting the metal chassis or anything else
that was what was causing noise on my car
really look at your swaybar...the rod ends like to get loose and you can back out the bolts tha thold the bar to the body...if you have a progress rear bar, its just hitting your cat back.
mouab18c1
Nov 15, 2012 11:25 AM
