90 CRX HF ????Transmission oil check????
Old Apr 10, 2011 | 01:11 PM
r90crxhf's Avatar
Default 90 CRX HF ????Transmission oil check????
Ive been meaning to check/change the transmission oil on my 90 CRX HF, but dont know how? (any pictures or guidance would be greatly appreciated) Im sure the oil hasnt been changed by previous owner... and Im currently @ 225,066 mls.
Old Apr 10, 2011 | 05:30 PM
Fo-Do Fanatic's Avatar
Default Re: 90 CRX HF ????Transmission oil check????
Is the trans an auto or manual?
Old Apr 10, 2011 | 06:08 PM
r90crxhf's Avatar
Manual Trans.
Old Apr 10, 2011 | 06:39 PM
John The G's Avatar
theres a drain plug on the trans and above that should be a fill plug ill look and c if i ca n find a pic
Old Apr 10, 2011 | 06:42 PM
John The G's Avatar
Old Apr 10, 2011 | 06:56 PM
89jdmcrxDOHCzc's Avatar
Be careful if the trans oil hasnt been changed in a long time with high miles and is really black, because changing it could actually cause transmission problems.
Old Apr 10, 2011 | 07:08 PM
r90crxhf's Avatar
Thanx for the pic 'John The G'!!! this will help alot... '89jdmcrxDOHCzc' your kidding me?!?! what should I do then? leave it like that... what kinda problems do you think it could give me?
Old Apr 11, 2011 | 03:30 PM
John The G's Avatar
idk bout it causein problems or not but i woul ddeffinitly change it
Old Apr 11, 2011 | 03:54 PM
If the trans. fluid has never been changed and its high mileage (super black) its actually better to just leave it like that because it gets used to all the gunk in there. If its changed it will clean it out and possibly cause slipping/ other problems. But hey dont believe me you can do what you want, just trying to give you a heads up.
Old Apr 11, 2011 | 06:48 PM
John The G's Avatar
i suppose i cud c that
Old Apr 11, 2011 | 08:26 PM
r90crxhf's Avatar
that makes sense to me bro!... thanx for the heads up
Old Apr 11, 2011 | 08:34 PM
Nooch's Avatar
I don't know about that, I've personally never heard anything about that. If that were true then everyone would be ****ed once they forgot to change their transmission oil after awhile.
If you believe in this then at least change the oil slowly. Drain like half and replace half. That way you at least refill with some decent **** and then next month or whatever change half again and replace half. That way it "gets use to the new ****."
That is if you are believing in that.
Bad_dude
Apr 30, 2010 10:34 PM
Tonyl507
Dec 8, 2006 09:32 AM
mystikz2002
Mar 3, 2005 01:45 AM
Darwin022
22
Jul 28, 2004 05:30 AM
hondacrx90
15
Apr 11, 2004 06:50 PM
