Will 1996 B18B1 Water Pump work on 1995 B18B1?
Old Apr 10, 2011 | 12:59 PM
EJ8_Man's Avatar
Default Will 1996 B18B1 Water Pump work on 1995 B18B1?
Hi,
I'm having trouble finding a OEM Honda replacement water pump for my wife's 1995 LS. I did find a 1996 LS OEM Water pump but it doesn't say it will fit a 1995.
1996 Water Pump Part # 19200-P75-003, will this work on a 1995 B18B1?
Thanks
Old Apr 10, 2011 | 05:29 PM
fcm's Avatar
fcm
Old Fart
Default Re: Will 1996 B18B1 Water Pump work on 1995 B18B1?
The part numbers are not the same... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal so I am not sure, but they are both B18B1s so I would think they would, they sure look the same in line drawings. 94
Old Apr 11, 2011 | 09:45 AM
EJ8_Man's Avatar
Thanks,
Looking around on the net, from what I can tell, the Water Pumps are the same from 94-01 B18B1s
Old Apr 12, 2011 | 05:31 AM
Stock_LS's Avatar
check autozone.com and see if they both have the same part number.
Old Apr 12, 2011 | 05:37 AM
Bowl_of_Rice's Avatar
i always thought a1 ended in 95 abd b1 is 96 and up
Old Apr 12, 2011 | 06:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
B18A engines were used in 90-93 Integras.
Old Apr 13, 2011 | 09:04 AM
chriszal1's Avatar
Yes it does
ismael-robert
Jun 15, 2006 11:32 AM
808State
Apr 8, 2004 12:22 AM
MotorMilitia LS
Apr 1, 2003 11:00 PM
Dorikamu
Sep 25, 2002 07:44 AM
