YCP 84mm ITR spec , ring problem
Old Apr 10, 2011 | 12:26 PM
H&AIMPORTS's Avatar
Default YCP 84mm ITR spec , ring problem
i bought a set of ycp 84mm itr pistons and i ordered nippon b20z2 rings and the top ring is to thick to fit on the piston and then i tryed a oem b20b top ring and its to thick to and a b16a top ring fits in the top ring groove. any one got any ideas .
Old Apr 10, 2011 | 12:28 PM
93egSLEEPER's Avatar
Default Re: YCP 84mm ITR spec , ring problem
Do you have the top and bottom rings switched? just a thought.
Old Apr 10, 2011 | 12:45 PM
H&AIMPORTS's Avatar
no on the b20b b20z2 the oem specs are 1.2mm top and middle ring but on this ycp 84mm the top groove is 1.0mm and 2nd groove is 1.2mm .
Old Apr 10, 2011 | 01:05 PM
DDTECH's Avatar
Why wouldn't you order the rings recommend by the pistons manufacture in which you bought the pistons from.
Old Apr 10, 2011 | 10:55 PM
kyosoeg6's Avatar
x2...
every ycp kit ive bought has come with the wristpins locks and rings along with the pistons. although i will add the last set i purchased was a press fit and not a lock type pin.
dstappity
Feb 20, 2011 02:55 PM
RACEPAK
Oct 15, 2007 06:00 AM
DEADLYACURACCY
May 19, 2005 06:41 PM
Hoosier Daddy
Nov 7, 2003 12:53 PM
